Question about Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch
I have a Calibre 16. The date does not change automatically and I have to do it manually every morning. Time is ok.
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Date change on my Tag Aquaracer Calibre S
Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Posted on Apr 07, 2009
  • 2501 Answers
SOURCE: adjusatet time and date for my eco-drive
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Posted on Mar 03, 2010
escapement
  • 2334 Answers
SOURCE: Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Posted on Mar 25, 2010
Testimonial: "Thank U so much for the enlightenment, escapement. Your points really do ease me alot. Will go to retailer/svc shops and we'll see from there. Cheers!"
  • 6 Answers
SOURCE: how do i set time , day and date , lost
The problem, as I have just discovered, is that when you go to the Citizen watch website listed above, you will get no help at all for the caliber 3100, "No document found..."
Try this link instead:
http://www.citizenwatch.jp/support/pdf/e310/e.pdf
Yes, this is the actual link to the full manual for the Caliber 3100 watch
Posted on Mar 29, 2011
How to seconds hand
Hi Johar,
I will advise you to contact your manufacturer to avoid warranty void due to damage during the process of setting it. Try the link below.
Contact Us TAG Heuer
May 09, 2014 | Tag Heuer Grand Carrera Automatic Calibre...
Date pin is not moving.
Pull the crown out for one click (there is two). Then turn the crown either way. If the date doesn't change, your watch has mechanical problem. In this case you have to visit your nearest watch repair shop and ask for fix.
Rate me, please.
Aug 06, 2010 | Tag Heuer Monza Calibre 36 Link Automatic...
Time & date adjustment
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TAG HEUER watch manuals. Rate me, please.
Mar 31, 2010 | Tag Heuer Monza Calibre 36 Link Automatic...
How to change the date and week?
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
Hope this helps as it took me using the correct movement number on the url in the previous post (for Calibre 8700 the movement number is "E870").
Mar 22, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
TAG Heuer Carrera Calibre 16
Hi
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Cheers
Dave
Jun 21, 2009 | Tag Heuer Link Automatic Chronometer...
Rate me, please.
Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Open Questions:
See all Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch Questions
Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch Logo
137 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
