Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 435 x torq has no compression, where should i start to fix?
3 Suggested Answers
  • 376 Answers
SOURCE: We have a model 435 husqvarna 16
Yes, no problem
Posted on Jun 13, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Husqvarna model 435.Having trouble
Did you read the starting procedure in your OM? It is similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Flooding is most common reason for hard starting in 2-cycle engines.
IPLs and OMs for all Husqvarna saws can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 14, 2010
I have a Husqvarna 435.Hard to start.When it runs, it has no power.It does the same as if it runs out of gas.I loosen the gas tank plug, then it starts and I'm good for 10 minutes.I also have a Husqvarna...
Sounds like the fuel cap on the 435 is not venting properly. Change the fuel cap and do not overtighten. Should correct your issue. The 435 is a nice light weight unit.
Feb 14, 2014 | Husqvarna Garden
435 Husquavana is hard to start and when warm will not restart
Try putting a spark tester on the plug. Run the saw and when it dies see if you can generate spark by pulling the cord, if not your coil needs to be replaced. It would also be a good idea to check the compression. When the saw warms up you could be loosing compression which would cause it to run poorly or not at all. A good compression reading will be 100-150 lbs.
Feb 10, 2013 | Husqvarna 435-BRC-RB Chainsaw
Hard to Start
Do you have good compression, good spark and is fuel getting into the cylinder.? More information is required
Sep 11, 2012 | Husqvarna 435-BRC-RB Chainsaw
Tricks to starting 435 husqvarna
There is no trick, push the primer button as many times as it takes to 3/4 fill the bulb ( you cannot over prime it no matter how many times you push it ) pull the red start switch out and at the same time lift up until it locks up, crank the engine twice or until it fires, do not continue to crank, push the red stop button down half way, crank engine until it starts and runs, blip the trigger to bring to idle.
Sep 11, 2012 | Husqvarna Super Low Price 435 16" 40.9cc...
Husqvarna 435 flywheel sticks
look on the side of the cylinder head and see if that model has a compression release thats sticking can you pull it over with the spark plug out
Apr 22, 2012 | Garden
HIGH RESISTNCE WHEN STARTING.
If the machine doesn't have a compression release, you need to tie a better knot at the handle (melt the end of the cord with a match or lighter so that if forms a small lump, then retie the knot). I have a new model 435 Husky that does the same thing (no compression release). Good luck!
May 23, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Husqvarna model 435.Having trouble starting.Do I squeeze trigger when starting? Is there a trigger lock for starting?
Start Procedure
Cold:
Warm:
HusqvarnaUSA.com
06 1500198
Lou
Mar 14, 2010 | Husqvarna Garden
HUSQVARNA model 435 Difficult starting
the problem is in the ignition coil.it needs to be replaced.it is under warranty.its warranty is life time.call husqvarna and they will either send you a new one or send you to a husqvarna dealer to fix the problem.that is at no cost to you..............let me know if this helped.................
Jun 06, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
367 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
