Question about Kyocera FS-720 Laser Printer
Hi, working on a kyocera fs-720 with a strange led indicator error after power on. hope someone can shed some light into the problem. upon power on, it went through the normal start up sequence like both green and red leds are on, and then they blink alternately for about 10 times. then it comes up with a repeating pattern as follows: both leds on both off for few seconds both leds blinks 3 times green led blinks 2 times both leds blink once freen led blinks 2 times then the pattern repeats all over again. the machine didn't even try to turn over. the light pattern started right from power on. status monitor on the pc would first say printer not connected. then says it has a problem with the printing system and call for servise. page count is only 31,418 pages. hardly any work done although a few yrs old now. any help would be much appreciated. thank you. edit: does anyone know where to download a service manual for free? had already google but no luck. also, is there a cold reset sequence that i can try?
  • 6966 Answers
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
Follow the page
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
SOURCE: How to scan from Kyocera
There is a send button on the left of the control panel. after pressing send, use address book, and chose where to send to....obviously your address book must be setup first
Posted on Mar 15, 2010
  • 148 Answers
SOURCE: the 3rd light on my Kyocera FS-1020d is flashing red, no printing
The flashing is a code. Depending on if it is flashing fast, slow or so on...
Turn to page 32 of this manual for more information.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 15, 2010
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Kyocera fs-c5400 toner usage
I don't think you are looking at coverage I think you are looking at toner levels
Aug 09, 2017 | Kyocera FS Office Equipment & Supplies
I need driver for KYOCERA FS 720 WINDOWS 7
Hello pusana11
You can download the driver directly from here: 7
Click on the download link and follow the on-screen instructions.
Hope this helps.
Nov 19, 2010 | Kyocera FS-720 Laser Printer
Printer FS720 Kyocera: both leds on both off for
read here :
Jul 02, 2010 | Kyocera FS-720 Laser Printer
I can't get a drive for laser printer kyocera fs 720 in pc with windows 7. has xp driver for fs-720
attach fs-720; windows 7 will recognise but fail to install
click on 'unspecified device fs-720' in devices and printers
click to upgrade/install driver
use driver specified above (xp)
should install properly
Feb 14, 2010 | Kyocera FS-720 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
Aug 25, 2008 | Kyocera FS-720 Laser Printer
Red light error
Hi Folks, I have just had the same problem with a Kyocera FS-720 that also had the red/orange attention LED staying on permanently after being turned on. Turned out to have an empty toner cartridge. After replacing the toner cartridge, printer is as good as new again.
Charlie T
Mar 20, 2008 | Kyocera FS-720 Laser Printer
Top 3 lights blinking on printer
The flashing of the LEDs you describe indicates a error. If you call the Kyocera Help Desk they can tell you what the error is based on the order and color of the LEDs. They can be reached at 800-255-6482.
Aug 18, 2007 | Kyocera Mita FS-1030D Laser Printer
Kyocera FS-720 Laser Printer Logo
99 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
