Question about Garden
I have a toro 2008 toro recycler walk behind mower and i was using it in high grass and it stalled out. I attempted to restart it and the pull cord was locked. Need help trying to get it to start again.
    Novelist:
    Champion:
  • 222 Answers
I hope you've got oil in it and didn't seize the engine. If you hit something that stopped the blades then you may have busted the timing key, which is underneath the flywheel. It could be busted and jammed up underneath there. If you're not familiar with taking that apart, then you'll need to bring it to a professional. It's actually a simple repair if in fact that is your problem. You pull the flywheel off (easier said than done w/out a gear puller), then you take the old timing key out and match it up with a new one and put it all back together. Again, not sure if that's your problem, but you at least need to take the top part of the mower apart to determine if the pull-cord / recoil is still functioning properly. Should just be 4 one quarter inch bolts to remove on top. In other words, first determine if the recoil is not functioning or the engine is not turning. WARNING! NEVER TURN THE ENGINE/BLADE WITHOUT FIRST DISCONNECTING YOUR SPARK PLUG WIRE. TURNING THE BLADE COULD START THE ENGINE AND CUT YOUR APPENDAGES OFF? Hope this help. Good Luck.
James
Posted on May 27, 2011
How to replace grass deflector
I have provided a link on how to change the discharge chute on a walk behind lawn mower. It is usually pretty straightforward across manufacturers so it should be of help to you.
But in quick terms, you lift the chute cover that holds it in place, remove your current deflector, and insert a new one! It's easy!
Best of luck!
How to Replace the Discharge Chute on Toro Walk Behind Lawn Mower
Jul 14, 2015 | Poulan Pro PR550N22SH 22Inch Briggs ...
Toro Recycler engine doesn't rev up when control arm is engaged
check the throttle spring in the front of the engine.It is hooked to a loop and when going near a bush it will push in and slow the rpms down.If you locate it pull it out and the RPM"s should increase.
Jul 25, 2012 | Toro Power Lawn Mower
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Toro pull cord won't rewind
You have to open up the starter and reattach the spring that works with the pull cord. A royal PIA.
Sep 16, 2017 | Toro Personal Pace CARB Walk Power Mower
Toro self propelled 22 inch recycler lawn mower not picking up grass
is there to much old grass built up under the mower?did you damages the blades
Apr 06, 2012 | Toro Power Lawn Mower
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
I have a self propelled Toro walk behind that does not have a throttle control. Stalls out if grass is just a bit high. How/ where do I adjust throttle
Most new mowers do not have a throttle adjustment, the motor has a govnor that helps the motor speed up when the load requires it. The first thing you should check is that the blade is sharp which makes it easier to cut the grass. If the grass is still too high for the motor to keep up, it's usually easier to raise the deck (lower the wheels) so you are not cutting as much grass on each pass. Then lower the deck to where you want the grass height to be and make a second pass.
Jun 06, 2011 | Toro Power Lawn Mower
Lawn mower stalled while cutting grass and cord
Check under the mower to see if anything is lodged in the blade, preventing it from turning. It that is clear, then the motor may have siezed up. possibly due to lack of engine oil
Sep 20, 2009 | Toro Garden
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
