Question about Sony BDVE300 Theater System
Sony bdv-e300 Cooling fan or blower makes loud noise. Where can I find the part number and supplier for this fan? thanks
  • 4,234 Answers
This is not a part that is typically replaced and is not listed on the standard replacement parts list. Try cleaning out all dust that you can see. Then, if you have access, try oiling the motor itself. Quite often all that happens is that some dust gets stuck in the oil and creates an imbalance.
Please keep us posted.
Thanks,
Dan
Posted on May 23, 2011
My toyostove laser 56 is still making a humming noise. I followed suggestions posted earlier and bearings in the blower motor were bad so I replaced the blower still getting noise, but not as loud.
Sometimes the blades on the fan itself can be out of pitch, which can cause the noise that you are writing about. You may need to replace the fan as well. It can be off just enough, that you can't really tell, but enough to make the noise.
Feb 05, 2017 | Heating & Cooling
Why is my fan so loud when i start my 1998 isuzu rodeo ls
cooling whom or what?
you (cab blower) , the engine RAD, the front, condenser
try to point and say this fan here, makes noise.
a place, pretend the helper is totally blind,
or even use photos., (shock)
Jun 26, 2014 | 1998 Isuzu Rodeo
Cooling fan makes a loud noise
You may need to remove the blower motor and check for debris in the box, or a failing bearing on the motor.
Sep 25, 2012 | 2003 Chevrolet Monte Carlo
Sony BDV-E300 doesn't open Tray
See the below side of the set there is a hole use hair pin to eject your disc.Do not too much force on it other wise you will broken any part.
Oct 30, 2010 | Sony BDVE300 Theater System
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
Makes loud noises
Although there may not be any gas parts involve you should have gas technician work on the unit. Depending on the noise your hearing it could be a number of things, if its making a scraping noise it could be that your front drum glides are gone allowing the drum to ride on the frame of the door. glide part numbers are 306508. if the noise you hear sounds like a grating sound it could be that your blower wheel has something caught in it and is now rubbing on all of the fan blades on the blower.blower part number is 33002797. if you hear a loud banging noise you could have a rear bearing issue. both roller bearing part numbers are y303373.hope this helps
Thanks
Oct 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
SONY KDF-50WE655 Cooling Fan
There are three fans: 1)Cooling fan(on the optical block)part# 1-787-057-11 2)Ballast fan part# 1-787-081-11 3)Upper optics fan part# 1-787-460-11 Also make sure you don't have a noisey iris motor in the optical block (verify by adjusting the iris settings in the menu and see if the noise level changes)
Sep 19, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony BDVE300 Theater System Logo
222 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
