Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
My 48 inch tv have a curve like green streaks line on top of the screen
  • 1153 Answers
SOURCE: no picture on tv screen
When you say no picture, is there any sound or noise coming from rear of set when you try to turn on. If so then you have no high voltage and maybe a cap in the HV line that is bad. If no sound at all, then maybe a fuse or open resistor in powersupply.
Posted on Aug 13, 2007
SOURCE: Green curved lines going across my t.v.
change the green lamp
Posted on Sep 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: Green bent line on 48 inch jvc
Check for a burnt resistor on the convergence circuit board. This is usually what happens when the green gets distorted as the green is not adjustable only through the service menu so its either a burnt resistor or a leaky capacitor. Resistor is far more likely. Let me know if you need any further information.
Posted on Jan 24, 2008
  • 4 Answers
SOURCE: JVC 65 inch projection tv
thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
Posted on Feb 16, 2008
  • 3 Answers
SOURCE: my 48 inch jvc tv has a green color to it what can
Okay so the green color that you see on the screen is because the coolant inside of the green picture tube is gone bad (it suppose to be cristal clear but now it is brownish and that makes the green color run all over the screen.) That just happens over time and I'm guessing the picture tubes have never been serviced. Now you got two choices
1- The easiest and fastest way would be to take it to a local repair shop and have them service the coolants of your picture tubes. I'm guessing it would run you about $165 or so to get them done (the three of them red,green and blue)
2-On the other hand you can do it yourself. It is not hard at all but it does require a lot of attention.
After the picture tubes have been serviced you'll notice the big difference.
You'll actually have a much brighter and sharper picture just like when it was new.
Let me know if you decide you want to do it yourself so i can post the instructions for you.
Posted on Aug 24, 2009
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Bluring at the top section of the TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 11, 2007 | JVC AV-56WP30 56" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
18 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
