Question about Kodak Document Scanner Microimager 990D Path-Through Scanner
I am looking for Microfilm machine with feeder ? i am asking if Kodak still producing this kind of machine. BR,
    Problem Solver:
  • 7 Answers
No. You can get a used one from ebay.
Posted on Jun 04, 2011
How do I correct stitch length mechanism to produce 6 stitches per inch?
the stitch length is governed by the cam action connected to the walking foot
that means that the stitch length is governed by the amount of material that is pulled through in the period of time that the needle comes up and goes down
normally the cam action is set by the stitch length lever/ reverse lever
if there is a necessity for a longer stitch, the cam would have to be changed on the drive shaft underneath
That will require a discussion with a sewing machine mechanic to determine if there are cams or other linkages that can be fitted to alter the stitch length for the manufactured maximum
Oct 09, 2016 | Sewing Machines
How do iget the material feeder to come up, it won't feed material on its own
Are you lowering the presser foot? The lever is an up/down feature on the very back of the machine behind the needle.
Are the feed dogs (the little teeth under the fabric) set on "darning?" If so, the machine will not move the fabric under the needle. There is a knob or setting somewhere on your machine for this function.
http://quilting.about.com/od/quiltingglossaryf/g/feed_dogs.htm
You should get a user's manual, if one is available, search for:
Make + Model + the word "Manual"
or contact manufacturer support
or at least spend some time watching sewing machine videos on YouTube.
Apr 11, 2016 | Sewing Machines
Need a article from sunday times 2001
Go to the newspaper and ask to look through their archives or go to library and look it up on microfilm.
Nov 20, 2013 | 2001
I lost the operation manual for my Kodak Carousel Custom 860h slide projector and need to obtain one
The best place to check for a copy of the owners manual would be the George Eastman Museum in Rochester, NY. They may have it on microfilm there, and maybe will help you out. Because this model of projector is so old, chances of a dealer still having a copy are slim to none. Good Luck!!!
Jul 10, 2012 | Kodak Office Equipment & Supplies
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Jan 20, 2012 | Office Equipment & Supplies
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
PROBLEM SOFTWARE CAPTURE kODAK DSV 2400 SCSI
You need to convert it to a Minolta MS6000 to use
other software packages and download the Twain driver for it.
The firmware on the 2400DSV will need changing via the service
mode to the Vendor name for MS6000.
This would involve a service visit by a Kodak Rep. and
should take no longer then an hour.
Dec 12, 2008 | Kodak 3000 DSV Film Scanner (35 mm), Film...
No Directions
Kodak.com->consumer prod->prod support->printers-> chose printer model->click user manual
Aug 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak Document Scanner Microimager 990D Path-Through Scanner Logo
61 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
