Question about Garden
Stihl fs38, full throttle when i try to trim, motor bogs out on me
sparksflyin
  • 47 Answers
SOURCE: issue wont run on full throttle, bogs out
check the spark arrestor in the muffler for a clog
Posted on Feb 08, 2009
  • 279 Answers
SOURCE: THE THROTTLE CONTROL SPRING CAME OFF THE CARB ON
Look to see which one has a worn spot . That is the one I would use. If it isnt that one, try the other. Good luck...Lee
Posted on Sep 24, 2009
lindsay836
  • 677 Answers
SOURCE: i have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Posted on Feb 08, 2010
  • 36 Answers
SOURCE: weed eater bogs down when i try to give it full
have to adjust the high on the carb. should have, 3 screws, 2 that are together is your h for high, and L for low. the one by itself is for idle. when mackine is running, squeeze throttle and adjust the high til it clears up, if it stalls real fast, back counter clockwise while off, and try to restart it, if worse, go the other way. i do mine by 1/4 turns. keep count of turns in case your going the wrong way! hope this helps!
Posted on Sep 22, 2010
  • 111 Answers
SOURCE: trying to find an ignition coil for a Stihl FS38
I would go to the dealer locater on the Stihl USA website. http://stihldealer.net/locator/ And see if you can order it from your nearest dealer. If they can no longer order the part in for you, then I would look on Ebay. There are a large number of dis continued parts on there.
Posted on Apr 05, 2011
Fs38 Stihl weed trimmer extremely very hard to pull with sparkplug in but no problem with no plug.
A hard pull on that unit would indicate a sheared flywheel key. The key is part of the flywheel. Check to see if there are 'rub or scrape' marks on the outside of the flywheel. Adjust coil clearance to .010". Coils on those models are normally very reliable. Use a spark tester for lawn mower engines. Preferably with a light in the center of the tester wire. If it its an adjustable tester, adjust the gap to at least .065 to 0.85". The light tester should produce a bright orange light, the adjustable tester should produce a bright blue spark. I cannot find specs on those models, as dealers use the 'light in wire' type tester.
Mar 07, 2017 | Stihl Garden
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
REPLACE TRIGGER IN STIHL FS 38
Heres the illustrated parts diagram showing the beakdown on the handle and location of the trigger mechanism. If you want the full parts manual, i can send it to you. :)
Apr 20, 2013 | Stihl Garden
My stihl 441 chainsaw runs but wont rev. at full throttle it bogs down.
clean the carburetor, replace the air filter and check the spark plug gap. .
Apr 18, 2011 | Garden
Need to replace line on FS38 Line Trimmer. No instuction manual. It must be an easy procedure. What diameter line and how is it done?
I googled your fs38. It is a Stihl FS38. The first sight on the search comes up with an 82 page operating manual from stihl.ca
This should help.
Good Day.
Oct 25, 2009 | Garden
THE THROTTLE CONTROL SPRING CAME OFF THE CARB ON MY FS38 stihl trimmer. Which hole does it go back into? Thanks.
Sep 22, 2009 | Garden
Stihl leaf blower motor dies when i try to give it full throttle
If the low and high speed screw are adjustable give them a try. Start with one turn on the low and two turns on the high speed. If these screws are fixed then you will probably have to put a carburetor kit in the carb. I hope this has been of some help. Donnyb60
Mar 18, 2009 | Garden
Issue wont run on full throttle, bogs out
Nov 22, 2008 | Garden
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
