I need to order a replacement DLP lamp for Model#HL P 5085W is online the only place to reorder?
  • 2,326 Answers
Click here to find the lamp for your TV.
Posted on Aug 15, 2008
    Sergeant:
    Champion:
  • 258 Answers
Pretty much it is. The manufacturer will have them. Or you can ask a local TV shop, but they may want to replace it in the shop.
Try Light Bulb Supply
http://www.lightbulbsupplyinc.com/
or Bulb Direct.
http://www.bulbdirect.com/aboutbulbdirect.php
Ken
  • 10,594 Answers
Hi, may I know exact model and brand of your TV to provide you helpful info.
I cannot find Samsung DLP HDTV 1080p Model # HL-85087W Lamp # BP68-00580A anywhere . Can somebody please help me ... I need the Lamp . My tv picture is faded
Try website like Tvrepairworld.com to buy and replace.This website deal with entirely on DLP tv and almost every parts for DLP tvs parts there is.
Sep 03, 2011 | Televison & Video
I HAVE A SAMSUNG DLP HLT5075SX/XAA AND IT STARS TO GET BRIGHTS LITLE DOT ALL OVER THE SCREEN WHAT IS THAT IST A PART THAT I NEED TO REPLACE?
Maybe your color wheel breaking up, if hit goes no picture or might be the lamp. If color wheel you can see it if you remove the back panel (UNPLUG TV FIRST) it's next to the lamp. Color wheel cost
Appox. $100 & If Blub Cost $75-$100 both can be bought online. Shop by you model #. If not sure what your doing call TV service Tech.
Good Luck!
Oct 09, 2010 | Samsung DLP HL-P5663W 56" TV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
How do i remove the lamp to replace it?
remove small plastic cover located at lower right corner on the rear of the machine (1 screw).remove cover. lamp is held in place with 1 screw. remove screw and pull lamp out by its' handle. install new lamp (do not touch any reflective parts on new lamp) and re-assemble in reverse order.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
I have samsung DLP, when i turn it on it makes a lound continous sound from the back of the tv, no pic
This set uses a color wheel, part number is:
BP96-00674AYou can remove the lamp and look where it faces--it is a round plastic wheel with segments that are different colors---if you remove the lamp and look in the direction it faces(you may need a small mirror to look) if it is shattered or missing segments of the round wheel---it is your problem.
If it is shattered or damaged you are lucky--Samsung sells this part separate---it is located in the optical light engine--you can find instructions for replacing it on the internet--if you decide to do this let me know--I know a few tricks to a good replacement of this kind of part. From Samsung it is about 125 dollar part---You can search on Ebay with your model number(or the part number) and find it for much less---search the part number I gave you there and you will find it. This wheel turns at 14,000 rpm and they eventually lock up and or shatter. The set will detect no motion or improper motion of the wheel and may shut the set off.
I do this here for free, so if this helps you give me a vote here---IF you have any questions or need more help--contact me here.
SD TECH (San Diego)
Aug 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Lamp replacement troubles
It is not a correct replacement lamp. Look for the "lamp code" on the side of the set. Make sure the replacement lamp has the same number.
May 19, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-R5056W 56" TV Problem
How old is this TV?
I think its time to replace Lamp.
Oct 03, 2008 | Samsung DLP HL-P5663W 56" TV
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
http://fixyourdlp.com/blog/?cat=4
Jan 16, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5063W. . .no lamp!
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
