Question about Poulan Garden
How to fix the Pull Cord on a Weedeater GHT 225 Hedge Trimmer?
Nic61
  • 1073 Answers
SOURCE: does anyone know where I can dwonload a users
Hi!
Yepp, i can help you! There are 5 diferent ones of that GT225
I dont know witch one you have so i'l give all five here:
HEDGETRIMMERWEEDEATER --> GHT225 ( 952711803 )
Manual: View
Parts Manual: View
HEDGETRIMMERWEEDEATER --> GHT225 LE ( 952711803 )
Manual: View
Parts Manual: View
Manual: View
Parts Manual: View
Manual: NO MANUAL AVALIBLE
PArt Manual: View
Manual: View
Parts Manual: View
Or you can go to this site and type GT225 in the search window:
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Good luck
Nic
Posted on Apr 22, 2009
lemmingleejn
  • 173 Answers
SOURCE: Weedeater hedge trimmer will not stay running.
Firstly, make sure that the fuel mixture is good, as old or incorrectly mixed fuel, is a possibility.
Then as long as the air filter, and spark plug are ok, check that fuel is entering the carb. If so, you can adjust the timing, by expanding or reducing the gap between contact, and the magneto/coil.
You can also adjust the timing, by changing the gap on the plug too.
There ya go,
FixedYa!
Don't forget to rate, thanks ;)
Posted on Aug 01, 2009
  • 10865 Answers
SOURCE: carburater fuel mixture settings
your best bet is to buy one small bottle of poulan oil, which will be added to one gallon of gas.
Posted on Sep 12, 2009
Biggdex35
  • 333 Answers
SOURCE: how do i replace the pull cord on the ht-22
Remove the housing with the coil in it. Remove the screw on it, its the screw with about 3/8 washer on it. It is where the old rope was hooked up, and should still have a piece of it under the washer. It has a D shaped groove under it. take the new rope and burn the frays on it make it stiff and small. Turn the pulley around and around until it gets real tight, and align the hole in the pulley with the hole in the shroud. Take a c clamp or visegrips and clamp it in place if you can. I just hold it, then feed the rope through the hole in the shroud and pulley and rap it round D shape groove. Replace the screw and washer. Tighten it up then let go of pulley. It should zip up real quick and all way to the handle, and be real tight.
Posted on May 11, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: not getting spark because i loosened the adgustment screws
GAP ON THE COIL ? USE A MATCH BOOK COVER. SPARK PLUG FOLD THE MATCH BOOK
Posted on May 26, 2010
Carberator adjustment on weedeater ght-22 h screw anf L screw
Turn the "L" screw in until lightly seated, then turn out 1 1/2 turns then lightly seat the "H" screw and then turn it our 2 turns.
Apr 16, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
GHT 225 Trimmer Replaced primer bulb, Starts OK but, will not keep running.
Try adjusting the low side screw on the carb. Back it out about 1/8 of a turn at a time until engine continues to idle. If this this doesn,t solve your problem then you will have to disassemble the carb and replace the diaphragms and fuel filter screen.
Nov 26, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
Where can i find a primer bulb for my weed eater ght-17...it's split. Do i need another part or can I just get the primer bulb?
You can get a primer bulb at any local lawnmower repair shop. These are less than 5.00 and very easy to install. the bulb primer is sold by it's self.
Best of it
Gary @ Fix Ya
Sep 06, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Not getting spark because i loosened the adgustment screws
May 25, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Poulan Weedeater GHT-22 Hedge Trimmer Leaks Fuel Near Handle
Either the fuel lines that were replaced are a poor fit in the tank ( wrong diameter pipe ) or the pipes have been connected incorrectly to the fuel primer bulb.
Dec 13, 2017 | Poulan Garden
GHT-22 Hedge Trimmer Fuel Line Replaced and Still Won't Crank
to solve your problem i am sure you can solve your problem just visit at the link given http://toolsnyou.com/
Aug 09, 2017 | Poulan Garden
Ght225 Weedeater hedge trimmer
try sanding the fly wheel and the coil to get the rust off
Jun 17, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Garden Logo
175 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
