Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I purchased a 260 Pro 42cc. I just got it out and when I pushed the primer bulb it did not return to the un-depressed position. There was no fuel in the bulb. I pulled the lines and gas pumped out of one line and the other was dry. It never fired until I shot starting fluid into the carb. Ran for about 3 seconds and quit. If you think I have a plugged gas line, can you tell me how to check? Thanks for your help in advan]ce!
    Top Expert:
  • Poulan Master
  • 47,568 Answers
Because you interfered with it , the warranty is void and if you have a blocked line ( unlikely) then any repairs are at your cost
it could be a stuck valve under the primer bulb that is the problem so remove the bulb and check the valves operation
Posted on Jul 11, 2017
2 Suggested Answers
nedkelly900
  • 345 Answers
SOURCE: fuel lines from primer bulb and poulan 250 pro 42cc
the longer one goes to the carb
Posted on May 24, 2010
What is the correct position on primer bulb for fuel lines
Short side of primer bulb to the carb and long side of the primer buld to the fuel tank as it's the return line.
May 05, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replaceing fuel line and primer bulb in a poulan pro 260
ACE Hardware has everything you need, I have the poulan also and all you need is the torx screw driver and get the little clamps for the fuel line, I got the kit which had all in it...good luck.
Aug 05, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Primer bulb tightens
Sounds like it is filling with fuel...a good thing
May 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulanpro 260 chainsaw when i went to use it ofter 6 months,it would not start.had old stail gas. i change the gas,cleaned the air filter,check and cleaned the spark plug,still not starting. one...
Check the fuel filter, and muffler for plugging. Check the condition of all of the fuel lines. Fix or replace the primer pump. When you get it working right, push the primer quite a number of times to flush all of the old fuel out of the carburetor. Unless the carburetor is in trouble, you should be able to start the engine again. Hope this helps!
Oct 23, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel lines question. From the filter to the carburator Were do I place that line?. There are two conections One at the top side with a black nipple and one on the side of the carburetor , How can I...
The fuel line from the tank that has the filter on the inside end is the main fuel line and should go near the top of the carburetor. The primer connection goes to the lower connection. Remove the tank side line from the primer bulb and leave loose. If the bulb is working in the proper direction, it will pull fuel from the carburetor and into the primer (and normally expel the excess back into the tank). Once the bulb is filling correctly, re-attach the return line to the bulb. Try to start the engine. If ok, it should run. Hope this helps!
Apr 20, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Route for fuel lines of craftsmen chainsaw
In general, the routing is from the fuel filter in the tank, through about 3 inches of fuel line inside the tank, then through the upper wall of the tank near the carburetor position and up to the top of the carburetor. Don't make any sharp bends in the line or it will eventually kink at that point. The line within the tank should allow the filter to flop around to find the lowest pick-up point as the saw position is changed. If the saw has a primer bulb, it should pull fuel from the carburetor (at a lower port) into the bulb when it is pumped. Another line runs from the output side of the bulb back down into the tank to return fuel (no filter here). Fill the tank with fuel mix and attempt to pump fuel into the bulb from the carburetor (leave the return line loose for a test). If successful, attach the remaining line to the bulb, and attempt start. Hope this helps!
Apr 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
McCulloch Chainsaw carb not getting fuel
This is the same problem I have with a Mac 3200. I have: (1) A line from the primer bulb to the front port on the carburator. (2) line from fuel tank, with attached fuel filter, to the other primer bulb port. (3) Line from port on back of carb. to ????. I thought it must be a pulse line, but not certain, and don't know where to run it to. Please let me know when you find out.
Aug 13, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
44 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
