Question about Hunter Heating & Cooling
I pulled off my old thermostat and didnt label my wires, and I'm attempting to hook up a hunter thermostat #40170, I have 4 wires coming out the wall
    Sergeant:
    Champion:
  • 229 Answers
What you have to do is identify your power which is usually red. once you know what that is tap one of the other wires to that then see what comes on Fan,A/C Heat. Once you hit the wire to the Red mark them then hook it up. Also you can try going to the furnace and seeing what colors are hooked up there then do the same at the t- stat. If this help please rate me or do a testimonial.
Posted on May 23, 2011
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
I have a red, blue, white, brown and yellow wires coming from the wall and have no idea which wires to connect to my hunter44155c thermostat.
go to the other end of the wires, where they connect at the furnace -- properly identify where they are hooked to and then hook them up accordingly onto the thermostat. If you removed the other thermostat, I trust you wrote down or know where the wires hooked into the old unit... you may be able to proceed from there with the manual. You could also call Hunter's customer service on Monday, if you can get by till then.
Best regards
Ck
Mar 06, 2011 | Hunter Fan Company 7-day programmable...
Four wires wrapped as two
Yes...just keep the four wires wrapped as two and then hook up as a two wire connection...
The two wires wrapped together just makes it work better if the wires are a bit too light...
The two wires wrapped together will function as one wire...
heatman101
May 06, 2010 | Hunter Fan Company 5/1/1 Programmable...
I believe the digital hunter thermostat say energy moitor 1
Find the 5-digit model number (example 40170) on your thermostat. Go to http://www.hunterfan.com and paste the number into the search field at the top of the page. If Hunter still supports this product, you should be taken to the support page for it which has a link to the product manual PDF.
Oct 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
3 Month baby and need help hooking up thermostat ASAP
The wire colours mean nothing. If your old one didn't have letters or you already disconnected it, you will have to go to the furnace. Under one of the panels there will be a control board to which the thermostat wires connect and this might have the letters printed on it. Trace them back and connect them appropriately.
If you have a furnace that is like mine (a single-stage natural gas one), chances are that R is +24V, C is common, W is heat call, and G is the blower. Y is generally cooling. The furnace could be turned on by connecting R, W, and G together, I suppose, if the above doesn't work... but it won't shut off automatically.
Jan 25, 2009 | Hunter Fan Company 5/1/1 Programmable...
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
129 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
