Question about Maytag Atlantis MAV7000
I am currently having a issue with my washer, It seems as if its drawing too much power as the lights dim through out the house, about 2 min in to the cycle the breaker trips, thr inse and spin cycle are still working, not sure what to do from here???
I WOULD SAAY YOUR HEATER ELEMENT IS FAULTY
Posted on Oct 16, 2011
WHAT IS THE CAUSE OF dash LIGHTS NOT ADJUSTING?
if all other light are high in brightness, and 1 is dim, there is issue with the circuit, or the light getting ready to burn out, it also is drawing a little more current to the light.
Oct 09, 2015 | 1996 Lincoln Town Car
Ticking noise
HI, This is the result of a damaged Power control board. This board is not regulating the incoming current correctly. This board should be replaced, immediately. This will cause the in-house circuit breaker to blow. The board is located behind a access panel, on the rear of the unit. Have it replaced, soon.
It may be mounted on the compressor platform, as well.
Dec 22, 2009 | GE GDS20KBS Bottom Freezer Refrigerator
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Won't switch from wash to spin...
You have a bad motor. Your motor turns in one direction to wash and the other to spin. One directions windings are bad. This is why it is drawing currant so bad. Sorry, seems I'm always the bearer of bad news.
Please rate solution
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Kenmore 90 series top load washing machine, when it goes into the wash cycle, the aggitator functions , but jerks and makes a clicking sound. Also, causes the lights to blink in the house. I...
Get a repairman in to check for a damaged drive train on the washer and an electrician in to check the wiring in your house
Switching a high power electric shower on can cause some voltage drop which in turn causes the lights to dim for a short period.
But having a washer stalling on wash doing it sounds as if you have some major issues with the house wiring.
May 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Spin cycle not working right
Your clutch/brake is locked up a must be changed.
Remove the transmission to access the clutch/brake assembly.
Mar 23, 2009 | Whirlpool Ultimate Care II GSQ9669L Top...
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Power dims when keyed dims lights fans ect.
your radio is trying to draw more current than your power supply can provide it, you need a power supply with higher current capability.
Nov 18, 2008 | Ranger RCI-2995DX Base Scanner
Sounds like solenoid is faulty
Yes, sounds like a faulty relay on the main bd. Could also be the motor is starting to seize up and drawing lots of current. I would suggest a technician look at the unit and test with an AMP probe to determine where and when the excessive power is being pulled.
Nov 08, 2008 | LG DLE5977 Electric Dryer
Washing Machines Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
