I have an iSub 2000 Rev A. It worked on my PPC iMac. When I got a new Intel iMac, it no longer works. The Apple System Profiler recognizes that it's connected to the computer, but the iSub doesn't show up in the Output devices list in Sound Prefs.
charcois
  • 763 Answers
SOURCE: Sony DCR-TRV530 firewire connection not recogized on Mac; won't import or capture video
try to use USB wire and then install the driver to your pc. hope that helps you!
CHARCOIS
Posted on Aug 21, 2008
Clearercape
  • 38 Answers
SOURCE: imac g4 cd drive
It;'s not a great Idea flipping the mac over they have a special stand to put them on when working on them. But it should be able to cope with it. Your mac is relatively old now. With all the moving around it could have just given up the ghost.
They are quite tricky to work on with the hard drive sitting on top and the cables running over and down the side there is a stack of heat generated there. Just make sure you put ll the thermal back in. If it's not a miss seated connection it could be a number of things. Cable, heads. Trouble shooting is quite tricky. As it is a desktop, in a lot of cases it is cheaper to buy an external DVD reader/writer. They are faster now!
You should be able to install OK when it is in terminal mode. You could run disk utility but more than likely you'll have to run the installation again.
Sorry, not much help.
Posted on Sep 12, 2008
honeybaked74
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
  • 9 Answers
SOURCE: External Speakers stopped working after installing leopard
go to control panel and find out what brand and modile your sound card is ten go to the manifactures website and download the drivers for that sound card but note unistall the sound card from the device manager first then once you have the drivers downloaded restart your computer and let windows find the driver for you if it says it cant find the driver install it manualy from the location of wich you saved that driver software you downloaded and the problem should fix itself
Posted on Feb 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Mouse not recognized as connected.
Hello there:
i have the exact same mouse and i had the same problem, go to device manager and look for the mice and pointing devices and open it up and see if it is listed there if it is and there is no problem showing there then right click on it and select remove the device then comfirm the removal of it. then look at the top where it says view and click on it where it says scan for hardware changes and let the computer find the device and reinstall the device the found new hardware wizzard will pop up in the taskbar once it has found it and it will reinstall the device for you and let you know when it is ready to be used... also if you move the usb sensor to a different port this also works ok?
i hope that these ideas will help you out. if not please let me know and there is more that we can try ok?
best regards
mike
(USN) RETIRED
Posted on Aug 04, 2009
I can't install epson r380 on new intel iMac
you will need to go to epson site try here Epson Stylus Photo R380 Ink Jet Printer at the drop down window next to Operating System: pick you operatind system then download
Apr 23, 2014 | Epson Stylus Office Equipment & Supplies
Wrong architecture
iMac G5 PPC is not compatible. It must be a intel PC or intel Mac to work.
Mar 22, 2014 | Apple iMac G5 Desktop
Old 2005 apple mac upgrade
Leopard requirements/10.5.x...
* Mac computer with an Intel, PowerPC G5, or PowerPC G4 (867MHz or faster) processor
minimum system requirements
* 512MB of memory (I say 1.5GB for PPC at least, 2-3GB minimum for IntelMacs)
* DVD drive for installation
* 9GB of available disk space (I say 30GB at least)
Classic/OS9 Apps no longer supported.
$45.00 on Ebay.com - You can't do Snow Leopard.
Jul 22, 2013 | Apple iMac G5 Desktop
My firewire port is not working
Driver issue. Verify sound card is showing up by connecting while viewing system profiler.
Verify support and download drivers from sound card manufacturer website.
Sep 26, 2012 | Apple 21.5" iMac Desktop
New Lion OS X computer does not recognize DCR PC109
Yes this is a 6 year old OS. Update it to Sierra or at least El Capitan.
Apr 19, 2017 | Sony Handycam DCR-PC109 Mini DV Digital...
Where is serial number located on imac i7?
Under the Apple menu select "About this Mac", then click "More Info" to open the System Profiler. In the hardware overview you will find your serial number.
Feb 06, 2011 | Apple 27" iMac Intel Core i7 2.93GHz, 8GB...
My IMAC will not boot up
the computer nor recognize a valid system working on it,..or the hard disk is damage
Jul 23, 2010 | Apple iMac 17" Desktop
Getting a new flat panel lcd screen to work on my imac 20 inch intel-imac p.c.
And the problem is?
I'm guessing that nothing comes up on the second screen.
Go to system preferences, displays and you should see your second screen there, ready to be configured.
May 20, 2010 | Apple iMAC All-in-one - 2.66GHz Intel Core...
Disk utility won't recognize that there is a superdrive neither does system profiler there is a dvd in the imac, which i watched about 12 hours ago. usual fixes (left click restart) won't do the trick. the...
They are a few thing to try althoguht you may have already tried them;
Pram and PMU reset -
First turn off the iMac, once turned off unplug everything from the IMac and physicallly unplug it from the wall, wait about 5 mins at this point, then just plug in the very basics (keyboard + mouse) - this is the PMU or power management unit aspect of this - the next step is a PRAM or paramiter RAM reset
To do this hold down the apple + alt + p + r key on your keyboard just after you turn on the iMac, and keep these held down, you should hear it chime as normal, now if you keep holding down the keys you shoud here it chime again, keep the keys pressed down till you have heard 4 chimes in total.
After that is done let go off the keys and the iMac should restart as normal - can you eject the disk now?
Sadly System profiler is normally very effective at picking up hardware that is installed in your Mac, The fact that it is not brining up anything would suggest that the super drive may be faulty or somehow disconnected, if you try the above and it does not work then i would suggest you call a AARC or apple authorised repair center and have the S/N: Serial number of your Mac ready - you can find your local repair center on the Apple website - for example the closes repair center to me would be Jigsaw Solutions LTD (www.jigsaw24.com) who are the UK's largest retailer of Apple abode and Quark.
I hope the above is helpful and that you do not need to contact an apple authorised repaird center!
Jul 13, 2009 | Apple iMac All-in-one - 2.66GHz Intel Core...
Canon CanoScan LiDE 60 not recognized by iMac or Mac Powerbook Laptop
Is the scanner detected in Apple System profiler? If so, what applications have you tried to access the scanner from?
Jul 04, 2008 | Canon CanoScan LiDE 60 Flatbed Scanner
 Grubhead
Grubhead
