Question about T-Mobile Sidekick® 3 Cellular Phone
Orange light comes on but doesn't charge ? - T-Mobile Sidekick® 3 Cellular Phone
    Problem Solver:
  • 12 Answers
There might be either problem with the charging point of the phone also try to charge using some different charger, if if does not work then require to replace the charging connecting point.
Posted on May 23, 2011
DS Lite Water Damage
1st I'd try the bag of rice trick,just leave it in ziplock bag of rice overnight to draw any moisture at all out. It may be per antsy water damaged and you're lucky that it still comes on at all,hassle but carry charger with you when you need to power up
Jun 30, 2013 | Video Game Consoles & Games
Tip
Kindle not charging
If your Kindle (any version) is not charging because the USB port has gotten loose, try this...wrap a small piece of aluminum foil around your USB connector - the end that plugs into the device. Be careful not to extend the foil past the end of the connector, you don't want to damage your device. Plug the cable in to the outlet and into the Kindle port as usual, then watch the orange light come on!
Kindle charging ports get worn out over time, the foil is a great conductor and makes a solid connection. Obviously, you'll want to try a different cable first, but if that doesn't work, this is free and easy!
on Mar 26, 2015 | Amazon Kindle Fire HD
How do I get the touchpad on when the orange light comes on?
Try pressing the fn button bottom left and F4 together
Feb 11, 2013 | Compaq Presario CQ62-112TU
MANY TIMES MY LCD DOESN'T ON AND AFTER SOME TIME ORANGE LIGHT COMES DOESN'T CHANGE TO GREEN FROM THE REMOTE OR LCD POWER BUTTONS. I AM FED UP FROM THIS THAT I GOES IN SLEEP OR OFF POSITION AUT
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 23, 2012 | Sony Bravia KDL-32BX320
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
Broiler burns but the bottom burner on the stove will not come on the glow igniter turns orange but the burner doesn't light also one eye doesn't light, the striker sparks but the burner...
FOR THE OVEN NOT HEATING
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
FOR THE SURFACE BURNER NOT LIGHTING The holes on the burner espically those around where the electrode are dirty/clogged. By using a paper clip/safety pin to push in and clear the holes then clean the burner up with some steel wool the burner should light. GENE
Aug 29, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
Ds not working after 3 weeks not being charged
that means it must be finished charging or check out a solution on lights not working
Jun 01, 2008 | Nintendo DS Lite - Onyx
T-Mobile Sidekick® 3 Cellular Phone Logo
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
