Question about Epiphone PR5-E Electro Acoustic Guitar Natural (with )
The pickup on my epiphone pr5 booms if i play loud, and if i tap the body anywhere it scratches and booms even with new battery
  • Epiphone Master
  • 5,603 Answers
Sounds like you are using incorrect settings on the amp you are using. Try all tone controls at 12 o'clock as a start. Excess bass boost is a good way to have the problem occur. Also back off the volume control. "Handling" noise or scratching from handling the guitar is NORMAL for this type pickup. Back down the volume and DO NOT boost the highs or lows to help with the handling noise problem.
Posted on May 24, 2011
What Epiphone model did I purchase?
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Feb 21, 2016 | Epiphone Music
Epiphone wiring diagram pr-5e
Your best best is to contact Epiphone Customer Service. Generally they're quite helpful. Here's a link.
Feb 11, 2015 | Epiphone PR5-E Electro Acoustic Guitar...
Cant get the buzz out of the high E string on my Epiphone les paul guitar
A buzz on one string is not due to a pickup fault. It's rather a too low string height at the nut or a string slot that is either too wide or has too deep of an angle towards the tuner. It could however be that you had the pickup too close to the high E string creating excessive string pull.
Jul 04, 2012 | Epiphone Les Paul Studio Electric Guitar
Epiphone EJ 200 CE/AN Electro Acoustic Guitar Wiring Diagram
Does this guitar have a esonic 2 system, if so the other pickup is piezo pickup located under the saddle, there should be two wires coming from the pre-amp just remove the pre-amp from the body and make sure that the two wires are still plugged in and attached to the pickups, these are plugs like a small headphone style plug, just check these and the wires are held in by small wire clips,one of the wires may have came out of the clips...hope this helps I will look for a schematic for you and post it if I find one...Good Luck!!!
Sep 23, 2017 | Epiphone Music
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
Can the epiphone p/ups be changed to gibson's, is it worth it ?
Yes, the pickups can be changed.
However; In my opinion this is not worth it. Pick up a pair of aftermarket pickups for a better sound that will fit your playing style.
-Sheeves
Sep 21, 2010 | Epiphone Les Paul Studio Electric Guitar
Minimal to no bridge
Sounds like you have some microphonic pickups. Only thing to do is replace them. This would be caused by the guitar being hit against something or being dropped.
Feb 03, 2009 | Epiphone Les Paul 100 Electric Guitar
Problem with the pickup sound on the 'g' string on my epiphone les paul standard
Hi ! Must be a problem with either the nut or the g-saddle in the bridge of the guitar.
Good luck , Stefan from Sweden
Nov 10, 2008 | Epiphone Music
Epiphone volume and tone controls
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
Oct 27, 2008 | Epiphone Music
Epiphone PR5-E Electro Acoustic Guitar Natural (with ) Logo
120 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
Robert Graf
Are you an Epiphone Music Expert? Answer questions, earn points and help others
