I have a cadet ZA152 wall heater, turned on Tstat, unit sparked, now fan but no heat breaker did not blow???
Buffalo12980
  • 625 Answers
SOURCE: Not a cadet but a King
shut off the breaker, then, remove the front grill. look for a device about the size of a nickel. could be fastened to the upper case. this is called a klixon overload. there are numbers stamped into the side of it. one of these are either temperature or an amperage value. get a replacement from an electrical supply house. it is probably blown. it is in series with the element. its purpose is to open [then reset] when an increase in current is evident. it is a bi-metal device - two dissimilar metals that bend at different rates when current is applied to it and opens a set of contacts.
Posted on Nov 16, 2007
SOURCE: Cadet wall heater
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Posted on Oct 20, 2008
  • 5 Answers
SOURCE: heater won't blow heat and keeps running
first try to pull out the little white button on bottom left side. if it is already pulled out, then take cover off, lightly press on the center dial as you adjust the little adjusters that are in the dial. should be two of them, the first should say off set to 90, second one says on set to 130or 135. these steps may work. if not then one of the wire connections may be loose.
Posted on Apr 26, 2009
SOURCE: my cadet c202 heater is running the fan is blowing
I work in a motel and replace these heaters quite often, Cadet C202, a 240v 2000 watt wall heater. Most of the time when they blow cold air it's because the heating element is broken. First turn off the circuit breaker, then remove the heater from the wall. If you take out three screws, slide the top cover off, bend the two little tabs and take out the heating element, you can examine it and usually you will find a place where it is broken, it's like a big spring. Replacement elements can be ordered from online stores such as reliableparts.com Be very careful, 240 VAC is very dangerous! <!-- from fixya rte -->
Posted on Aug 16, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Dayton kerosene
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Feb 20, 2011
Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 21, 2017 | Coleman Heating & Cooling
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
Cadet C151 heater not producing warm air.
take your tstat off jump out the wires red green white together. if it works like that then your thermostat is bad. if it doesnt then it is in the unit.
Mar 24, 2010 | Cadet Manufacturing Com-Pak Plus C151...
When air conditioner is turned on only heat blows (in heat and cool) but not in fan only mode. It is a package unit, and has an old mercury thermostat, I was going to replace the thermostat with a digital...
Hi; Ok lets try something. Kill the breaker to the package unit. Then remove the outer electrical cover where the tstat wire goes into. Be very carefull if warm outside some wasp could be looking for a home...Now look at the tstat wires connected to the control board or check the wirenuts if no board.Is every thing secure.No look for any chaffing of the brown insulation on the tstat wire at the unit, under the house, at the tstat. You can remove the first cover by pulling gently from the bottom up. Now You will see several small flst tip screws inbedded in the plastic base. loosen the screws but do not try to dislodge from the plastic base. The screws are done this way for a reason,so You dont loose the little suckers. No remove the subbase gently. Look at the connections are they secure. Question is this a heatpump or air conditioning with gas or electric strips for heat...alpharome416 PS
As far as the fan switch goes. The tstat has two choices for fan operation(auto,on). When in auto fan will come on durring operation only. In the on position the fan will run continous cooling or heating all day long...alpharome416
Feb 22, 2010 | Heating & Cooling
My cadet c202 heater is running the fan is blowing cold air but no heat, is it the thermostat or heating elements or both???or ?????
Dec 31, 2009 | Cadet Manufacturing 67507 Heater
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Heating not working like it should
The fan for the A/C should blow harder than in heat. The fan should be on high for cool and low for heat. You can change the heat setting for medium but I would not recommend it because it may make heat coming out feel less.
Nov 21, 2008 | Heat Controller Thru-Wall/Window Air...
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
