Screen going black can see some of the picture behind the black screen
  • 10,594 Answers
Hello, may I know exact model and brand of your TV to provide you helpful info.
Posted on Aug 15, 2008
Black screen e442
probably your led panel went dead. check it in bright light if there's moving picture behind which means your back light get busted. try to connect it to external monitor to double check
Nov 26, 2013 | Computers & Internet
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
SD TECH
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
My 5 year old plasma tv has sound but no picture what could this be?
No picture as in a black screen? or a picture with snow (noise)? If there is no picture at all (black screen) with no menu display when menu button is pressed, then it sounds like the y-sus and the z-sus boards are faulty..These are the boards located usually on the left and right edges of the screen. They are fused and these can blow, severing the supplt to the boards. These boards are used to deflect the electrical charge across the screen. If you have no picture then it sounds like both boards are down
Jul 31, 2009 | LG 42LC2D 42 in. LCD HDTV
Black box in front of picture
If it's the box,just press the CCD button on the controller until you see CCD off .(Try this one first since it just started with the box)
If it's the TV,just go into the setup options and turn off the closed caption feature.
Jan 07, 2009 | Insignia Digital-to-Analog Converter for...
4 Scrolling black boxes with the picture showing in the background
PIP DISPLAYED IN ALL FOUR CORNERS OF PIX. UNPLUG UNIT MOMENTARILY TO RESET. or the pip modual has failed.
Mar 16, 2008 | Televison & Video
Screen blocked, viewing screen behind is ok.
FORLDS, go into "menu" and turn "CC" or "closed captioning" off, end of problem :) BMW Rider
Jan 07, 2008 | Televison & Video
Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Fuji s5000
CCD sensor faulty ( sits behind the lens inside and this device converts light into image ) . If the camera has not been abused the repair ought to be done free of charge because properly manufactured CCD or CMOS unit should last 15 years !
Aug 29, 2007 | Fuji FinePix S5000 Digital Camera
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
