Question about Sony Video Cameras
Error E:61:11 at handycam DCR-SR68E - Sony Video Cameras
welcomejee
  • 10594 Answers
SOURCE: error code C:31:42 on a Sony Digital Handycam DCR-TRV530
C:31:42 shows following error..
FG fault during normal drum operations.
Its related to drum assembly (video head) in camcorder and possible reason can be drum stuck with some thing, no power to drum motor etc.
Posted on Jan 19, 2009
Fixe_You
  • 1800 Answers
SOURCE: SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Posted on Jun 28, 2009
  • 30 Answers
SOURCE: sony handycam DCR-DVD108 - - error e:61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously(FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
Posted on Mar 29, 2010
SOURCE: sony handycam DCR-DVD608 Error E:61:00
Had this error E:61:00 on my DCR-DVD650. I took it apart and found a panel about 1" x 0.25" that exposed the motor that drives the zoom. Played with it a little until it started working again. Put it back together and I'm working again...time will tell.
Little tricky getting apart, but not too bad. There's a panel right against the body inside the door with display--where the SD Pro card goes--which pops right out. Need to do this to disconnect ribbon cables.
Posted on Nov 29, 2011
fieqry
SOURCE: sony handycam dcr-trv19e mini
remove the battery from the unit, then put it back again and do the tape ejection normally
Posted on Oct 01, 2012
Buffer over flow movi recording time
The error description is not very precise. Anyway:
You should check the Harddisk for Filesystem errors/defective blocks. Don't know if the Camcorder has a built-in function for this. It could also help to delete all data and to reformat the drive.
Otherwise you may need to replace the harddrive (While you are at it, you could put the drive into an external USB cage and check it with your computer). Sounds like a complicated task.
Jan 17, 2014 | Sony DCR-SR68E/S Handycam(R) PAL Video...
How to download hard drive to computer
the manual explains all that. lost it?
if yes, its on the sony site.
i have the same cam.
1: connect their cable.
2: load CDrom, and load the Sony USB software.
it needs special uSB drivers for older OS, (unstated OS)
3: run said software. or see the files via program manager.
what computer, PC or MAC, or Linux?
Oct 03, 2013 | Sony DCR-SR68E/R Model DCR-SR68E Handycam...
Can I Download Soft ware of Sony Handicam DCR- SR68E ?
Software is not required to download the videos from this Camcorder.
Jan 17, 2013 | Sony Handycam DCR Series DCR-SR68 Digital...
HDD format error
Format the hard drive, if you still get that message the drive is broken and needs to be replaced by a professional.
Jun 11, 2012 | Sony DCR-SR68E/S Handycam(R) PAL Video...
My new Sony DCR-SR68E shows hard disk format error and E:31:00 error every-time I star it. It doesn`t shoot anything. It doesn`t even get formated. Please let me know if there is anyway to solve this...
SonyDCR-SR68E HDD Format error
Go to Menu-Show Others-Media format-HDD-Yes-Yes-ok
you must be solve your problem.
Never format your camcorder with NTFS or FAT system format using your operating system Windows.
Sep 18, 2011 | Sony Handycam DCR-SR100 Camcorder
When I format my sony DCR-SR68E then it show "unable to format" and its show a time "E 30:00" and when show in my lcd panel HDD format error. Please help me.
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem
how are you trying to format this usb hard drive it might be listed as a mass storage device
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 21, 2011 | Sony DCR-SR68E/S Handycam(R) PAL Video...
Windows XP. connect DCR-SR68E. XP asks for driver. and fail install
These handycams are newer models packed with technology. While windows XP is an old windows and would not have its driver by default. If you have got a Disk with the Cam, insert that into the Drive and try to install driver from there. If you haven't, then you will first have to remove the defaulted driver and then download a new driver to run with it.
To uninstall the defaulted driver follow the steps:
  • Click on Start
  • Go to Control Panel
  • Double click on Device Manager
There you will see a yellow question mark for the driver of the cam coder. Right click on it and click in install. Then try connecting the Camera again and installing the driver. It if doesn't work, let the windows search in online for you. If it still doesn't work, try to find the driver for the camera on the Sony's site for your particular Cam.
Apr 02, 2011 | Sony DCR-SR68E/S Handycam(R) PAL Video...
Video Cameras Logo
41 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
