Question about Sunforce 11260 Pure Sine Wave Inverter
My power inverter not working-just i connect to 12v battery and i like to use for 110 v ac
Lost 120 volts on coachmen Somerset dreamcatcher 32.5 while hooked up to power pole. still have 12 volts.all converter fuses and power panel circuit breakers good. Power from pole is good.
First, I'm not a Coachmen RV Tech. (but most DC to AC inverters are not brand specific.)
* Check inverter fuse (on actual inverter frame). Replace.
* Check DC voltage at inverter. Should be 12 (or 24 VDC) depending on your system battery supply and inverter.
* Check the DC cable connections; crusty, dirty? Cut all power. Remove and clean terminals. Re-connect and check.
* DC okay? Check 110 VAC power at output of inverter. No power? Replace inverter. (possible power spike damaged it or it over heated)
* 110 VAC okay? Check the power panel breakers. If stuck in middle then turn all the way off to reset and turn all the way back on to activate. Check AC power at outlet(s)
* Still no power (at outlet)? Check all outlets. If some still works then there is a problem with the power (wires) distribution. You will need an electrician to trace the wires back to the break in circuit.
* Be safe. check your warranty and call for service.
* Note; your inverter may be on a separate warranty.
Aloha, ukeboy57
Jun 05, 2018 | RVs
Telefunken tlcd
you would need a power inverter to take the 12 volts up to 110/220 volts ac.
The battery would not last very long. You can get inverters to connect to your vehicle power system.
Mar 26, 2014 | Televison & Video
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
Greenlight but no ac out
voltage regulator is bad. Most likey bad caps.
May 16, 2013 | PowerBright Power Bright 2300 Watt Power...
175 watt 350 peak inverter 12v dc to 110 ac need a fuse but don't know what size to use. old fuse is missing.
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
Jan 30, 2011 | NexxTech 175W Power Inverter
Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
May 20, 2010 | Eliminator MotoMaster Mobile Power...
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Problem with getting inverter to work...
Inverters works from 12v carr battery or backup battery, you can not charge the inverter you msay killed your inverter if you connected to 120v wall mount...you use the inverter to give you AC (electric) from 12v battery. if your tv is 12v you need to know how much needed to get the correct connrection as output and input.
Nov 07, 2008 | Vector Maxx SST Power Inverter
Sunforce 11260 Pure Sine Wave Inverter Logo
52 people viewed this question
Top Sunforce Electronics - Others Experts
Robert Hunt
Tom Chichester
Are you a Sunforce Electronics - Other Expert? Answer questions, earn points and help others
