Question about Zoom 4501 Router
Hi Everyone, Wanted to ask about a strange issue I am having with these routers and the corresponding dongle (Zoom 4595). Using a standard Three SIM I am able to connect to the internet using the dongle when plugged into my laptop via USB. However when I plug the adapter into the Zoom router it will not connect to the internet. There is the initial dial-up phase where the dongle goes through several colours. After this it simply flashes green but it does not make a connection. The settings are the same in the router as they are for the dongle so I have no idea why it should not connect through the router. With the router I tried updating the firmware, resetting to factory defaults all to no avail, I also tried another router and had the same issue. When looking in the stats screen it provides the signal strength and the network name but simply states HSPA USB MODEM and Connecting, however it never actually makes a connection! Any help with this issue would be great as this is really bugging me!
  • 104 Answers
SOURCE: Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Posted on Nov 16, 2008
  • 104 Answers
SOURCE: Signal showing but no connection (zoom 5590 x6)
Hi……there could be a number of reasons why you can’t connect. I’m assuming you have rebooted both laptop and router to see if this helps, so let’s move on to some basic troubleshooting steps to start with:
  1. Can you pick up the internet through a wired (Ethernet) connection between the laptop and the router? If so, this narrows the problem down to your wireless connection.
  2. Can you login to your router again, and check to see if MAC filtering has been enabled. To find this, go to Advanced Setup > MAC filtering. If the status is ‘enabled’, disable it, Save changes, and try to connect wirelessly again
  3. If MAC filtering is off, and you still can’t connect, go to ‘View Wireless Networks’ on your laptop: disconnect from your network, wait 30 seconds, and reconnect. When prompted, re-enter your network key very carefully. Can you connect now?
If you still can’t connect, please come back to Fixya, and let me/us know the operating system on your laptop. Good luck…
Posted on Jan 17, 2009
dvancamp
  • 13 Answers
SOURCE: HP laptop won't always connect to zoom router
Every time I have ran into this issue it is because of wireless interference. Try these steps:
1) If you have a cordless phone, try turning it off (unplug the base). Some cordless phones operate on the same frequency that your wireless network does.
2) Change the wireless 'channel' your network is on. There are 11 channels. For best results, choose either 1, 6 or 11. Most wireless routers come preconfigured on channel 6. So if your neighbor has wireless and is operating on the same channel, your leptop may be getting confused.
3) Make sure your laptop and wireless router are operating on the same encryption level (WEP, WPA or WPA-2) and speed (A, B or G). Some older laptops do not support WPA-2.
Good Luck!
Posted on Feb 01, 2009
  • 51 Answers
SOURCE: laptop won't connect to wireless
Try giving your wireless card a manual IP address. Open network connections (under Start menu or control panel), right click your wireless card, then choose properties. Highlight 'internet protocol' and choose properties then select 'use the following IP address' fill in the details as below
  • IP address 10.0.0.5
  • Subnet mask 255.255.255.0
  • Default gateway 10.0.0.2
  • Preferred DNS Server 10.0.0.2
Posted on Jul 03, 2009
govinda123
  • 2260 Answers
SOURCE: No Internet Connection with Zoom 4501 & HUAWEI K3520 3G Dongle
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Posted on Dec 19, 2009
Can i use connect dongle as wireless adapter
Yes definitely ,I think i need lots more information about router version, IEEE standard.
basically adapter that uses mobile phone networks to provide broadband as a WiFi Dongle while USB WiFi adapter can be used to connect your PC to and existing wirless network provided by a wireless router.
but first you should find out what kind of Internet router you are using and always purchase a Wi-Fi adapter that is compatible with the Wi-Fi standard of your wireless router.
read more information
for more http://www.ebay.co.uk/gds/Buying-a-USB-Wi-Fi-Adapter-Dongle-Can-Make-You-More-Mobile-/10000000177329841/g.html
If you still not able to solve follow us Linksys Router Support .
Apr 17, 2014 | Computers & Internet
I have a 60LN5710 LG Smart TV. I want to connect to the internet. I plugged in an LG AN-WF100 dongle. At first I couldn't find my AP. A few days later I found it and connected to internet, however I...
Sometimes these types of issues are difficult to troubleshoot remotely (in this case, you've got 4 potential points to address: TV, dongle, router and ISP.)
If your TV and/or dongle utilize specific ports outside of the "norm," you may need to manually configure your router to allow for this.
Depending on the distance your AP/router is from the TV/dongle, the signal may not be strong enough. (Or, the signal coming from the AP may be present--you can confirm this with another wireless device--and maybe it's just the dongle itself has a poor range.)
Also, the dongle itself may be defective. Generally, there is some form of configuration that needs to be done, one way or the other, either on the computer, or on the TV itself (like a setup option).
Most likely, it's not an ISP-related issue.
Also, try to contact Sharp Technical support. They should be able to give you some recommendations that may prove helpful.
If all else fails, see if you can track down one of the dongles listed as being compatible in the TV manual, or find a dongle that's advertised as being compatible with your specific television, as that might be your best bet.
Good Luck!
Oct 12, 2013 | LG ANWF100 Wireless dongle
For aboutfive years i have successfully had a orange live box installed in my home and, again successfully have 2 wireless computers. How ever my oldest computer doesnt have wireless option installed on to...
First be sure to check the drivers for your Netgear WG111 are up to date and correspond to your Operating System. It is important to note that there are three versions of the WG111. If you visit the Netgear's Knowledge Base site you can see the difference between the 3 versions (v1,v2 and v3) and select the one that corresponds to you. If you don't know what version you have look for a v1, v2 or v3 after the model name:
After you determine which version you have, let suppose its v3, click the link corresponding to it and download the Software Version 2.0.0 (Supports Win 7) if you are using Windows or the WG111v3 Mac OS Driver Version 1.0.0.0 if you are using a Mac. Once you download the file, run the executable file and install the driver/software for your device.
If your problem is not with drivers then youshould look at you Wireless Network Setup. Please Check that the router has a source of a working internetconnection plugged in correctly via an ethernet cable. Also, routers need fromtime to time to be rebooted. Try disconnecting the router from the power sourcefor 15 to 10 seconds and connect it again.
Post more details concerning your OS, the router you are using and what type ofinternet connection you have(DSL or Cable).
Mar 05, 2011 | NetGear WG111 802.11g/b Wireless Adapter
Special characters using numpad shortcut keys microsoftword 2007
Not exactly sure what you're asking here but if you're looking for characters like ¿ ? ?, or just letters with accents, here's an ASCII Table:
http://www.table-ascii.com/
Some of those you can copy and paste, the ones that are JPEGs you will need to hold the right Alt key. While holding it, press the three digit "Dec" number which corresponds to the letter you want to use.
Jan 21, 2011 | Microsoft Office Computers & Internet
Special characters using numpad shortcut keys microsoft 2007
Not exactly sure what you're asking here but if you're looking for characters like ¿ ? ƒ, or just letters with accents, here's an ASCII Table:
Hi i have a dell dimension 4600 and i wanted to get a wireless card but when i ask some someone they said to me is it a N router or a G ? can you tell me which one it is
They are referring to the wireless router you are using, not the computer. If you get an N wireless card, it should be backwards compatible with a G router. N is a higher speed standard than g but you will not get the speed of N if the router is not compatible. Look up the router on the internet to find what band it is compatible with (B/G/N).
Jan 26, 2010 | Dell Dimension 4600 PC Desktop
It is very easy.
Dec 14, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Can't connect with 2nd computer...
1st.  What brand and model # of your router? 2. The router cd should be run only on the computer u have connected to the router with a network cable. Your vista laptop. Is it connected with to the router with a cable? 3. If so, it will be the one used to configure your router for wireless setup. When you ran the setup it should have gone thru Wireless Setup. It will ask you for an SSID. That is a name you will give your wirless network. It can be anything you want. just remember it.  It will also ask you to setup security for your wireless network. follow the instructions to setup a password. write it down. This is an important step so anyone cannot just logon to your wireless signal an start using ur internet connection or gain access to your computers. 4. when u setup your dongle on your kids computer it will search for wireless signals in the area. you will look for the one u setup in the previeous step. you will select it and it should ask you for the passkey you setup. once connected you will have access to the internet.
Think of your router as a private radio station and the wireless usb dongle is the radio. The only way your computers can tune to it is using the dongle and if you know the name of the station (your SSID) and the passkey.
Mar 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
New laptop, automatically connected to belkin54g, suddenly stopped working. please help!
well maybe you have to connect properly, fist of all i only know the windows vista version but go to .start, connect to, then a list of all available routers will appear, select yours (or the 1 your using). it will then ask you for a password, type it in. click connect. wait for it to load and there you go
i hope that helped
Oct 01, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
LOGGING ON TO WIRELESS NETWORK
Possibly your MAC address is not in the routers allowed list?
Dec 04, 2007 | HP Pavilion ze4315us Notebook
Open Questions:
Zoom 4501 Router Logo
106 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
