My HP Officejet Pro 8500A is leaking Magenta ink...tried different brand new hp cartridges and it still leaks...
  • 4 Answers
SOURCE: printer is leaking ink
See http://www.fixyourownprinter.com/forums/inkjet/22399
Posted on Jan 06, 2008
rakeshpramod
  • 234 Answers
SOURCE: Ink is leaking
Is the printer in warranty or extended warranty, If yes then you will get a free replacement from HP, or try this bellow link:
http://partsurfer.hp.com/cgi-bin/spi/main
Posted on Aug 29, 2008
Joed911
  • 4338 Answers
SOURCE: Won't accept non-HP cartridge
You ask "Is this a common problem with non-HP cartridges? " It is a possiblity.
Where did you purchase the cartridges from?
This error might be caused by defective printhead or sensors
Are you removing the 2 protective caps from the cartridges?
Read this HP page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01451117&lc=en&dlc=en&cc=us&lang=en&rule=17507&product=3203059
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 23, 2009
daryn720
  • 113 Answers
SOURCE: black ink cartridge is leaking and black line is running down back of page
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
Posted on Jun 02, 2009
websnail
  • 419 Answers
SOURCE: HP Officejet Pro L7780 sucking out ink of new ink cartridge
Is this a refillable cartridge you're using or a genuine HP OEM...
If it's a CIS, refillable or some kind of cartridge which is not made by HP then chances are the ink nozzle has failed and allowed the yellow ink to leak everywhere...
There are a lot of problems with these 3rd party cartridges and I would never recommend using anything other than a refilled HP cartridge or a genuine one.
Hope that helps.
Martin
Posted on Jul 11, 2009
How do I change the ink cartridge?
You can search user manual to see how to change ink cartridge correctly:
Hp Officejet 8500a Manual Download
Jan 03, 2016 | HP Office Equipment & Supplies
Maintenance steps to resolve continuous cycling at startup
Dear
Its standard procedure to do the routine clean the head (nozzles) of the ink cart. at the time of start(power on or from sleep mode).
Thanks.
Feb 04, 2015 | HP Officejet Pro 8500a Plus All-in-one...
Hp 8500A won't print if one ink cartridge needs to be replaced
Its simply because the cartridge is not making a good contact with its socket.
1-switch off the printer and totally unplug it 2-clean the cartridge properly
3- check the cartridge clip
4-return cartridge and send a feedback to us
Jul 09, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Hp 8500a has new print heads and new ink and now cyan has stopped printing
Hi I have two split pipes in my Hp 8500A printer where can I get replacement parts as it is not printing correctly.
Feb 08, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8000 Wireless Printer - Magenta cartridge leaking. How to fix?
If the cartridge itself is leaking then you need to simply replace the cartridge, if the nozzle on the printer is leaking then if the printer is under warranty have it serviced.
If the printer is not under warranty then you will want to replace the printer simply because inkjet printers are not cost effective to repair. It is the sad truth about inkjets.
Comment if you have further questions.
Aug 09, 2011 | HP Officejet Pro8000 InkJet Printer
I have a hp officejet pro 8500a and it has started leaving a black line on all copies when the original is fed thru the ADF. What is causing this??
Hi, Change first black color print head cartridge just open cover then replace black print head cartridge.close cover wait for ink cartridge reinitialize if ready print test again.if same print having black line all copy needs to replace also black ink cartridge.
Jun 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Ink cartridge installed but cartridge light continues to blink
Have you only replaced the magenta cartridge, or have you also tried the print head. A bad print head can cause the ink to read as empty or clogged.
Mar 15, 2010 | HP OfficeJet Pro k550 Printer
Ink clog between magenta cartridge and print head.
print head may be burned out try cleaning it then tap the cartridge and try a test page to see if it prints, if it still does not work try a new cartridge if that does not work then the print head is burned out, it may be under warranty you can go to www.hp.com and input your model and follow the trouble shooting guide and if you can't fix it you can register for free live chat help with the problem and it may be under warranty, many printers are having problems with this color cartridge drying up and causing problems not only hp but other brands as well. I suspect the pigment drys up but am not sure about it.
Feb 11, 2010 | HP OfficeJet Pro K8600 Printer
Whant to buy Hp 88 Printhead
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/product?product=501369&lc=en&cc=ca&dlc=en&lang=en&cc=ca
click "Shop For Supplies" to access:
https://h30042.www3.hp.com/SureSupply/
Which of the HP 88 cartridges:
C9385AN HP 88 Black Officejet Ink Cartridge
C9386AN HP 88 Cyan Officejet Ink Cartridge
C9387AN HP 88 Magenta Officejet Ink Cartridge
C9388AN HP 88 Yellow Officejet Ink Cartridge
do you need to order?
Nov 20, 2009 | HP OfficeJet Pro k550 Printer
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
146 people viewed this question
jasbo
jasbo
