Question about Grilling
I bought the hybrid grill and put it together and I got to the last box the porcelain grate was broken was waiting for response if they are going to send me one called several times and no response do I go back to store and return it?
    Brigadier General:
  • 4,736 Answers
Jon, if you have waited a reasonable length of time for a return phone call from the manufacturer and haven't received one. Return just the grate to the place you purchased it, along with your Proof of Purchase.
Posted on May 24, 2011
Bought a members mark hybrid grill model number gr2071001-mm. Attempted to put it together but when I opened the box I discovered that it did not come with an instruction manual. Where can I find one at...
check with the store where you got it, if they dont have it go to the manufacturer of the grill. they will need the information from it and should be able to give you one.
Dec 24, 2014 | Grilling
The grill grates have to be replaced often because the porcelain comes off. Where can I get another kind of grate to fit the CGB36ru since your price of about $70 times six is very expensive. What keeps...
Hi steve tell...
I would measure the inside of the grill and go to a welding shop and have them make me a stainless steel grate made from expanded metal that would fit my grill and never go back to the porcelain coated grills and their sticking,cracking,rusting again.
It will be somewhat expensive, but it will be worth it and it will be a one time purchase.
Most of the porcelain grills get faults in the porcelain from heating and cooling that allows greases and salts from cooking to seep into and get behind the porcelain to rust the steel grills that the porcelain is bonded to.
That is what causes the porcelain to pop off...the rust.
Please take time to rate me
Aug 31, 2011 | Thermador CGB36RU Grill
How does the Brinkmann grill model-810-2545-w rank I want to get an idea before I buy it & is it a good grill--Ken
The best answers you can get from those ones who already purchase it. Click here Amazon com brinkmann grill (seller with most reviews) and read the reviews. I hope this was helpful. cheers
May 13, 2011 | Brinkmann Smoke 'n Pit Professional...
Are porcelin flavor plates removable? If so, how?
If you're referring to Powder-Coated Porcelain Cast Iron Adjustable Grates. Yes, they are removable. They just lift off the grill. As do the tent shaped Flame Tamer/Flavorizer plates under the grill grates and above each burner. They should be removed regularly for cleaning.
Hope this helped you and Happy Grilling!
Apr 18, 2011 | Cabana Kitchens CLA480 (LP) Grill
I need instructions for a viking gas grill...I have the smoker insert and need to know how to use the grill to smoke a round roast or tenderloin.
In order to use the smoker box, remove the last set of porcelain grids and flavor generator plate on the right hand side of the grill. Set the smoker box in theopening so that the front and rear tabs rest on the grill frame.
Always soak the chips in water prior to putting them into the box. Use the "HIGH" position to start the chips smoking, then reduce the heat to a lower level to prevent them from drying out and flaming. If the wood chips do flame up, add a small amount of water to extinguish the flame. Use
caution when adding water to a hot box to avoid steam burns. This tray may also be filled with water to produce steam.
Whether smoking or steaming, the grill should remain closed as much as possible to maximize the effect. During extended roasting periods, it is normal to add fresh wood chips and water to the box several times. Limit the amount of times the canopy is opened-each peek adds about 15 minutes to the cooking time.
Wait until Smoker Box totally cools before trying to remove it.
Enjoy you roast or tenderloin!
Feb 10, 2011 | Grilling
Rusted Grill Grate
and why do you want to replace it? just use bit of wirebrush, scarape off biggest bits, wipe rest with cooking oil and use as normal.
after cooking wipe clean (do not wash!!!) and use bit of cooking oil again to preserve it.
Jul 19, 2010 | Weber Q Grill
I purchased new porcelin coated grates. How do I
My grill uses stainless steel cooking grids, so I had to look it up for cleaning porcelain. Here are a few websites that show you how to clean them. Hope this helps.
This one explains it on the 6th item listed titled: How to Clean Grill Grates.
http://www.gasgrillsnow.com/GasGrillHowTo.htm
This one has good overall recommendations for all cooking grid types.
http://grillparts.com/howto/grid.htm
And finally this one can help you as well.
http://www.mhpgrills.com/restor2.html
May 16, 2010 | Weber Genesis Silver A Grill
The grill grates on my Weber Q have rusted and porcelain has worn off in places. How do I get the rust off without doing further damage? My grill is still under warranty.
The weber Q-300 grate not only rust they start to sliver causing a health issue. My grates were rusting in about a year and a half. I called Weber and they sent me to new grates free. They are warrateed for 2 years. I said to the lady what if these grates start to rust, she said if it was within the two years call and they will replace them..
Apr 10, 2010 | Weber Q300 Grill
How do I clean my grill?
Use a grill brush, if you have porcelain grates then use brush for porcelain. If you have cast the wire brush one works great. Don't use wire brush on porcelain it will scrap it off.
Mar 03, 2010 | Weber Genesis Silver C Grill
Grilling Logo
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
