Question about Toys
I need a manual for the TDC model PTST-30012. It is 2 months old and the lights do not come on.
2 Suggested Answers
SOURCE: Malibu TDC PTST-30012 turns on in the middle of the day
1) Contact malibu lights directly.
Their site does not acknowledge TDC PTST-30012, so I cannot access a manual with best information.
Their products come with a warranty.
http://malibulights.com/customer_service/contact_us.aspx
http://malibulights.com/customer_service/owners_manuals.aspx
2) If unit can be set to override, you can buy cheap photo eye timer, and then plug power pack into cheap timer, but there is no guarantee this will work, or that power pack will burn out.
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
3) Buy ordinary power pack with dial-type timer, and then buy photo eye that fits.
http://www.intermatic.com/products/professional%20lighting/light%20expressions/accessories/ml814drp.aspx
http://store.nexternal.com/intermatic/categories.aspx?Keyword=ML814DRP&x=15&y=10
4) As electrician, I would not buy anything that costs more than $15 that comes with built-in photo eye that cannot be replaced.
Especially something as buggy as a low voltage power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Feb 28, 2011
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
How can i fix my honda 160i luxline 92 model starting difficulty?
Yes, you need to set your camshaft end distributor timing to TDC. (top dead centre). now you start vehicle, and adjust your distributor timing to 10% after tdc, on the coast or 8% inland
Jul 20, 2014 | Honda Accord Cars & Trucks
TDC low voltage transformer model DA 150 12 W reset button trips
There is a short circuit.
Copy following link to identify possible problem and download manual
May 02, 2012 | Hardware & Accessories
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
Hi, I have to reset the points on my RM6 Raleigh Runabout. Could you tell me how many mm's before TDC they should begin to open. Thank you. Lawrence Curley.
When the engine is not running, ideally the points open at TDC...they will advance once the engine is running.
If you don't have a timing light, an old trick I used to use was to get a string of christmas tree lights that had 10 of those tiny lights in series. Why 10? 120V / 10 lights - 12V/light.
If you have a string with 20, you can take 2 in series, but the idea is to clip out one of the lights and put it across your points. slowly rotate the crank in the direction of normal rotation, and the light should come on as you hit TDC (ignition must be on, so remember to remove the sparkplugs!)
If they are off, adjust them, and either come full circle, or go back at least 1/2 revolution and then come back to TDC slowly.
It's an old poor mechanics trick, but I tell ya, it works well!
Mar 14, 2011 | Triumph Speed triple Motorcycles
How to change my timing belt for a 97 mecury mystique gs 2.0
There are so many steps. After removing everything so you can get to the timing belt you need to make sure you have the engine set so the #1 Cylinder is TDC. Remove the old belt and re-install the new one. If you need step by step directions on how to do any of this I recommend you get the Haynes Repair Manual for your vehicle since it will show you those and give you instructions on how to make sure your at TDC. If you try putting that belt on without being set to TDC the engine is not going to run correctly.
Jun 23, 2010 | Mercury Mystique Cars & Trucks
Feb 14, 2010 | Intermatic Malibu 300W Power Pack...
I have power to machine because light comes on but motor does not turn on.
most of the time when your brush headlight comes on and the motor does not its inside the motor compartment, could be a loose wire to the motor or a bad motor
Jan 03, 2010 | Kenmore Quick Clean 30012 Vacuum
Replaced timing belt need do you start at TDC to
For all timing belts you should start with the crank sprocket pointing at TDC and the cam sprockets pointing at their designated marks.
You should be able to mark the old belt and and put corresponding marks on the cam and crank pulleys, then remove the old belt and transfer the marks to the new belt and install it.
Personally I would buy a manual as this would provide you with a step by step guide to performing the repair.
I am not positive that this is an interference engine, it looks like it is to me. If you are not accurate in your timing you will cause severe engine damage.
Jul 25, 2009 | Isuzu Trooper Cars & Trucks
Toys Logo
133 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
