Question about Craftsman Air Tools & Compressors
Craftsman permanently lubricated air compressor.model#919.165070. it wants to start but ends up tripping circuit fuse. the tank is empty of air. air filter is clean. why won't start running? I just started using it and it ran once but the second time it just quit. I unplugged it waited then replugged it. went to restart it and thats when it started to trip the fuse. can you help?
  • 89 Answers
SOURCE: compessor trips circuit
IT SOUNDS LIKE YOUR COMPRESSOR IS NOT UNLOADING WHEN IT SHUTS DOWN. YOU SHOULD HEAR AN AIR RELIEF SOUND TYPICALLY ON THE SIDE OF THE PRESSURE SWITCH WHEN IT SHUTS DOWN. ITS A SMALL VALVE WITH A TIRE VALVE THAT THE LEVER HITS AND RELIEVES THE PRESSURE FROM THE DISCHARGE LINE AND THE TOP OF THE PISTON.
YOUR CHECK VALVE COULD BE BAD LETTING PRESSURE BACK UP BUT IT WOULD BE BLOWING AIR OUT ALL THE TIME WHEN SHUT DOWN.
IF YOU THINK THE VALVE OR SWITCH IS WORKING AND WANT TO CHECK IT, LET THE COMPRESSOR BUILD UP AND SHUT DOWN, LISTEN FOR THE AIR RELIEF,IF IT DOESNT THEN CRACK THE DISCHARGE LINE AND SEE IF THERES ANY PRESSURE, MANUALLY RELIEVE THE PRESSURE THEN USE SOME AIR AND SEE WHAT HAPPENS. REPAIR VALVE ON THE SIDE OR CHANGE PRESSURE SWITCH $30-40.00. HOPE THIS HELPS. PLEASE REPLY. JODY
Posted on Apr 05, 2009
  • 135 Answers
SOURCE: Air compressor that trips my circuit breaker
Most garage curcuits are 15 amp GFI plugs and they won't run most compressors. Drain all of the air out of the tank and see if it runs. If so then you are going to have to add a 20 amp plug for your pump.
Posted on Jan 17, 2010
compman66
  • 169 Answers
SOURCE: craftsman 30 gal compresser trips circuit breaker
That number does not come up on Sears parts direct, how ever a start capacitor you can have tested at any motor repair shop and likely get one to replace it from them as well,,,and can almost guarantee it will be cheaper than from sears anyway.
Posted on Feb 25, 2010
  • 18 Answers
SOURCE: Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Posted on Jul 10, 2010
  • 449 Answers
SOURCE: wont cycle after first charge
check the start capacitor it might be weak
Posted on Sep 25, 2010
Breaker trips when you try to start compressor motor spins a little before tripping breaker
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
May 04, 2012 | Craftsman 33 gal Air Compressor 6 hp...
My Craftsman 15 Gal Air Compressor trips the electric breaker at start up no mater where I plug it in.
Apr 12, 2012 | Craftsman 15 gal Air Compressor 3 hp UMC...
Sears Craftsman Air Compressor power problem.
Check the compressor tank for any water, the symptoms are just what you would expect if there is excessive moisture in the tank.
Mar 06, 2012 | Air Tools & Compressors
I have a Craftsman (919.176820) 2HP, 12 gal. compressor. I starts fine the first time, it reaches full pressure and cuts off. When the pressure drops and it tries to start again, the motor lugs and trips...
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through searspartsdirect.com.
Feb 22, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Turn it on it buzzes and trips the fuse
One thing mine does, If it is plugged into a 15 amp circuit , it will do the same thing. It needs a 20 amp circuit to run, the start up motor on those things draw 16+ amps, and then run on 13. If it is cold, full of air, it won't run, if it has a cord of any length, forget it, It needs a big cord, 20 amp circuit, or no air in the tank and be warm. In the winter time we all had our compressors in the bathroom with the heat on, I though it was for us to warm up in, but it was for the compressors. I thought mine was the only that did it.
Sep 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Ingersall-Rand T 30 Model 2340 Motor overload trips when trying to fill air tank. How long should it take to fill the tank with air with tank empty. If tank is full it may cycle one time when using air.
You need to know the size of the tank before you can figure pump up time from empty to full. It sounds like you have a bad tank check valve. A bad check valve typically causes the motor overload to trip when starting.
May 21, 2010 | Ingersoll Rand 2340/2475 Electric Air...
1hp 4gal 2 tank Craftsman Air Compressor not Compressing
Try emptying the tanks completely. There should be a bleeder valve for each tank. Sometimes after sitting for a while with pressure, the compressor won't have enough power to start. If you get the same response with empty tanks, there is a problem with the pump pistons.
Dan
Jan 11, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compressor won't restart with any pressure in tank
try replacing the capacitor. a bad start capacitor will not let it start under a load.
Jul 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 6hp / 60gal air compressor
Does this trip on pressure or is it a breaker tripping? If you took off the intake then there is no pressure build up, thus it wouldn't trip the pressure switch. But would at the same time add a load to the motor. First check and make sure motor is wired properly, then check that pressure switch is wired properly and is adjusted to the right pressure. I don't believe that the intake tube would be clogged, it's a straight hole into the tank. But could be a possibility.
Oct 23, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
164 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
