Question about AEG Lavamat 16810 Front Load Washer/Dryer
AEG Øko-lamamat 617. When the maskin start filling water it wont stop filling and following the program futher on?
2 Suggested Answers
derrickbohan
  • 90 Answers
SOURCE: My AEG Öko Lavamat 86800
unplug it for a while and then plug it back and see what happens.
Posted on Dec 17, 2010
AEG 40850 - pump noise and running for long time, eventually showing error 20
There is a problem with drainage. Check the drain line connected to the disposal or peatrap. Make sure it is not plugged. Otherwise you can disconnect the drain line and put a wet vac on it to try to clear the hose
May 20, 2016 | AEG Dishwashers
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Aeg wont stop filling water
Should be a water level control switch.
May 11, 2014 | AEG Washing Machines
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Dec 17, 2010 | AEG L86800 Front Load Washer
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water....
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Nov 15, 2010 | AEG Lavamat 88840 Front Load Washer
Machine stops soon after starting
Many variables there on the AEG. Excellent machine but can be more difficult to repair than the other makes.(more interlocks etc).
Strangely enough, it is the basic things that go wrong making it possible to repair on many occasions. I would put about 5 litres of water into the machine manually then close the door and set the machine to spin. The drain pump motor should firstly pump the water out. If not, that could be the problem. If still a problem look and see what type of sensing device the machine has. ie. a pressure switch or a pulse counter. If a pulse counter, it could be defective and the machine senses the incorrect amount of water. If you still have a problem after that you need to contact me giving me details on the first start up with no water in the system. The machine is sequential and follows a set program.
May 19, 2010 | AEG L10500Vi Front Load Washer
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Machine doesn't start washing process
mine fille up with water puttaht is a far as it getes
May 22, 2009 | AEG Washing Machines
AEG Lavamat 16810 Front Load Washer/Dryer Logo
65 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
