Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
I have the Sony KDF-60XS955. It has a blue corner about 3 inches on the lower left-hand corner which is on all the time. Also, when there is a black screen, you can see small blue dots all over the screen.
  • 1,476 Answers
Momkennedy13,
You have the fatal Sony KDF optical engine issue. Sony has had most if not all these models fail prematurely. The solution is to replace the optical engine. The problem is they are not available as a new unit only a repaired unit so the problem will no doubt reappear in the future. Many people have had success with contacting the Sony customer service representatives and can usually get them to sell you a new unit for a couple hundred dollars. For my money that would be the best way for you to go. I have a tip at http://www.fixya.com/support/r7851924-sony_projector_yellow_or_blue_dots which explains the problem and offers solutions.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 23, 2011
2 Suggested Answers
milkburp
  • 416 Answers
SOURCE: Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Posted on Mar 17, 2010
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a permanent blue light encroaching the picture on the lower left corner of our sony kdf-60xs955 60". Replaced the bulb recently.
The Optical Block is probably the cause of the problem. I am not sure if it is still a Recall issue but due to the cost of the repair, I recommend you call Sony at 1800-222-SONY and see if they can assist
in the cost of repairs and also to help locate a Service Facility to confirm the symptom.
I hope this helps,
Skyassoc
Oct 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Large blue covering entire bottom right corner and blue dots
optical block failure call sony, they are a known fault on all rear pro sets from 2003-2007, they may replace for free, have extended warranty on this part.... there are lawsuits pending against sony over this problem
Sep 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a blue spot in the left corner of the
call up sony give them your m# with S#
some of this set are replamet for eng. but your eng is bad do you see in meuns?
Aug 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
KDF-60XS955 Blue dots all over screen. Lower left corner of screen has a small blue cone shape. Will a new bulb fix this? If yes how do I replace the bulb?
It is problem of light engine (optical block) in TV and Lamp replacement does not solve it.
TV needs replacement of light engine, that is costly part.
Jun 20, 2009 | Sony KDF-42WE655 Television
Sony Projection TV - glowing blue in corner of screen
That sound like the optical Block or otherwise known as the light engine
This still may be covered by sony's warranty
I would call them and see it is a very expensive part
Feb 08, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue hue on bottom of screen We have the same problem. A blue hue extending the bottom of the screen and now is working its way up the middle .
call SONY at 800 222 SONY and explain it to them and be prepared to have your TV fixed for free !!! the projection block is faulty do to outsourcing on that part for a limited number of tv's an mine was 1 of them , SOny took care of everything !!! good luck
Feb 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
