Question about U-Line Refrigerator Ice Maker
Icemaking is ok but I find water at the bottom of the frige .What seems to be the Problem tHIS A ULINE BAR REFIRERATOE WITH iCE MAKER
  • 1,116 Answers
Your feed line may have a leak in the line itself or in one of the connectors. This it the line that sends water to the automatic ice-maker. Check the line coming from the wall to the ice-maker connector and slide your hand down the line. You will find water somewhere along this line and you have found your leak. This should be very easy to fix.
Posted on May 23, 2011
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Kenmore refrigerator 71203100 ice maker does not make ice. I get water from the water dispenser inside the refrigerator, but no water in the ice maker. The metal bar used to turn the ice maker on and off...
The water inlet switch on the back lower is always the problem. It has 2 solenoids, 1 for water and 1 for ice. They never go out at the same time. Follow the water line to the frige and there it is. Turn the water off repalace the part and plug the frige back in. check for leaks and enjoy...
Mar 29, 2010 | Kenmore Refrigerators
I have water going through the water dispenser, but no water going into the ice maker. The infrared light seems to aligned with the receiver.
The water inlet solenoid on the back of frige has two valves that never go out at the same time. Follow the supply line to the solenoid. Turn off water supply, unplug frige and replace part.
Nov 06, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
My LG refrigerator model#26945TT does not make ice anymore. Any thoughts what could be issue?
Check the following
  • timer, which is located at the rear side of the refrigerator
  • open the freezer casing and check the thermostat
Aug 07, 2009 | U-Line Refrigerator Ice Maker
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
yes, there is 2 lines, one for the water and the other for the ice. you can take the back lower panel behind the frige and take a look at the water line coming from the house where it connects to the frige, you can disconet the line that goes to the freezer, and put the line inside of a container of about 1 litter, and waite for about 30 minutes it at to have some water inside just enough to fill the ice maker. if you donot get any water, replace that valve.
Dec 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
Uline ice maker
The trough gets refilled on each ice cycle, if it's circulating, then the water supply is adequate.Y
The exact model would be helpful, but you could call 1-800-779-2547 U-Line's tech line
or email OnlineService@U-Line.com for help
http://www.U-Lineservice.com
May 13, 2008 | U-Line Icemaker
U-Line Refrigerator Ice Maker Logo
174 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
