Question about Dehumidifiers
Dehumidifier has stopped working...it appears to be electrical..no switches are working and no lights are on.
    Brigadier General:
  • 4,736 Answers
Check the outlet that the unit is plugged into, to be sure that it's still has power. If it doesn't, a circuit breaker for that outlet may have tripped. Or the outlet receptacle may have a loose wire. Try plugging the unit into another outlet that is not on the same circuit, as the one it's currently plugged into.
Posted on May 24, 2011
Stopped working
Does it act the same as if the bucket was removed? Likely your fill bucket switch is not connecting. Remove the bucket, press the switch and try to run the unit. If it powers up and "works" then you need to make sure the bucket has a good connection with the switch. If this did not work, remove the connectors to the switch and electrical tape them together and try running this again. If it works, your switch is bad. Replace. If you leave it electrical tape connected, the unit will not turn off when the bucket is full.
Jan 06, 2014 | Goldstar DH504ELY6 Dehumidifier w/ 50...
Won't run
Check operation of the interlock switch for the condensate collector. I had a dehumidifier that would not run unless the collector was shoved in and held in place
Dec 29, 2012 | LG LHD65EBL Dehumidifier
I have a Whirlpool AD75UST humidifier that stopped running, almost like it blew a fuse or something. Does it have a fuse somewhere? Any other possibilities? Thank you!
Have you checked the receptacle it's plugged into, to see if it's still working? Use an electric lamp to check this. If the lamp doesn't work, the circuit breaker in the home's main panel has been tripped. Unplug the dehumidifier and reset the circuit breaker. Then plug the dehumidifier back in. If it trips the circuit breaker again, there's an electrical problem within the dehumidifier.
In answer to your direct question ... some dehumidifiers have a reset switch. It's probably on the back of the unit, above the water collection tub. if all else fails consult your Owners Manual's Trouble Shooting Guide. If you have misplaced it, you can download it from the Whirlpool Appliance starting at their home page.
Hope this helped head you in the right direction to solving your problem.
Mar 01, 2011 | Whirlpool 75-Pint Dehumidifier
The fan on my LG LHD45REL stopped working. Compresssor still works. How do I tell if the fan needs replacement or the control is faulty?
dear sir
if you can check by an electrical tester then first open control panel and check electric(main electric ) supply is reaching till the selector switch if its reaching supply the try to turn your selector switch on fan mode and check the connecting point of selector switch electric supply is now come on fan supply point ( where motor wire is connected that point ) if its working like this then its mean selector switch is ok and problem in fan motor , its need to replace .
hope answer the question
thank you
please vote!
Sep 30, 2010 | LG LHD45EL Dehumidifier
Dehumifier blows out my electrical switch in my electrical panel.
You definitely have an electrical short in the unit and should stop using immediately. Have it checked out by a licensed electrician. It is a very real fire hazzard.
Jun 07, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
"running" light on but motor doesn't engage
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 24, 2009 | Haier HDN455 Dehumidifier
My Fedders dehumidifier keeps reading full all the time
When you move the float up to enage the switch does it shut it off? If not you may need to adjust it
Jun 19, 2009 | Maytag M3DH30B2A Dehumidifier
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
118 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
