Question about Hayward Pool & Spa
Hayward ultra pro lx pump. tried turning the pump on and it doesn't run. hydro is going to the pump but it doesn't make a noise at all.. Any suggestions
mattofilms
  • 110 Answers
SOURCE: my hayward 1 hp pro flow lx pump initially primes
is your 'pumps' skimmer box 'O' ring in good condition?
do you have a hole or loose pipe work?
Posted on Jul 07, 2009
  • 93 Answers
SOURCE: how do I connect up a hayward pro grid de4820 to a pool pump
motor gets hooked to bottom ,top is outlet back to pool there should be a bottom drain plug hose to pool goes on top return and on pump inlet
Posted on Jul 14, 2009
  • 246 Answers
SOURCE: Noise at the valve on the my Pro Series Hayward Sand Filter
yuo may have air leak check gasket if clean check the inlet pipe add siicon around
Posted on Aug 25, 2009
  • 990 Answers
SOURCE: my hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Posted on Oct 03, 2009
SOURCE: We have an older model Hayward Power Pro LX pump.
well of course you need to make sure the filters are not blocked up, Skimmer basket etc......I have seen on few occasions the impeller shaft has broken, so the pump runs like it doesn't have a trouble in the world.....but the impeller isn't turning, therefore no water flow.
Posted on Sep 04, 2010
Hayward ultra pro lx pump, The On/Off Switch is stuck in the On Position, engine is not running and the breaker is Ok. The On/Off Switch doesn't even want to return to the Off Position. Any ideas what...
Unplug your filter pump motor and remove the back plate. Next, use an Ohm meter to test for continuity at the switch terminals. If you have continuity in both the on and off positions, then you must replace the switch. If not, then you have a short or the pump is wired incorrectly.
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward Pool & Spa
My Hayward pump was very noisy but now trips the breaker. I can turn the impeller from the rear pretty easily.
Hayward is synonymous with junk. Let me guess. It's been in service for about two or so years when the noise started. Eventually the motor will burn out. I've gone through two motors and a diffuser on my Hayward pump. It's already making noise again.
Jul 16, 2012 | Hayward Pool Products Hayward Power Flo LX...
Hayward power flo lx swimming pool pump is making a grinding noise
THAT IS A ABOVE GROUND PUMP AND THE BEARING ARE GOING BAD, ITS HARD TO FIND A SHOP THAT WILL WORK ON ONE OF THOSE PUMP-MOTOR SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING AND HAVE HIM LOOK AT IT TO SEE IF IT'S A FIXER OR NOT ? .JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
May 07, 2012 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
We have an older model Hayward Power Pro LX pump. The pump is running but no water is pumping through. Can't find a tech drawing.
Sep 03, 2010 | Hayward Pool Products Hayward Power Flo LX...
How can I tell if my noisy Hayward Super 1hp pump noise is in the motor or the pump?
99.9999% OF THE TIME its the bearings going bad, and need t be replaced asap.due to a bad shaft seal... search your area for your local pool pump motor repair guy with free testing. should be around $75 to repair it if caught in time.. here in florida lizards,frogs,grass and snakes and the such get into the motor and you can get that grinding sound but it will soon fade, but can restrict airflow and make your motor run hot and fail prematurely.. so if the noise doesn't fade in say a hour or two.. have it checked .. here is how to remove most pump motors just click on this link.. hope it helps ya .. jay florida
Jun 22, 2010 | Hayward 1HP Super Pump II Inground Pool...
Pool & Spa Logo
614 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
