Question about Xerox WorkCentre M-24 Color Copier
Please help me I need to print envelopes with my xerox work centre how can I
    Top Expert:
  • Xerox Master
  • 11,573 Answers
Xerox WorkCentre envelope printing
Posted on Jul 02, 2016
    President:
  • 2,072 Answers
Solutions for : How To Print Envelopes Using the PCL Printer Driver on a Workstation With Microsoft Windows 2000 / XP Operating System Solution : Print Envelopes Using the PCL Printer Driver on a Workstation With Microsoft Windows 2000 / XP Operating System NOTE: The PCL driver is the only driver supported for printing envelopes. There is no support for printing to envelopes using the Adobe PostScript® printer driver. It is necessary to complete all steps to successfully print envelopes.
NOTE: If printing through a server, changes to the driver must be made at the server level.
To set up the custom size paper for the printer:
NOTE: The setup of the custom size paper is a one-time step. Once the custom size is setup it remains an available paper size until it is changed.
  1. At the workstation, click on [Start], point to [Settings], then select [Printers].
  2. Right-click on your printer and select [Properties] from the menu. The Printer Properties window will be displayed.
    NOTE: Use the custom size paper in the printer driver when printing within an application.
  3. Select the [Configuration] tab.
  4. Select [Bypass Feed Orientation] and make sure it is set to Portrait in order to feed the envelopes long edge feed (LEF).
  5. Select [Custom Paper Size].
  6. Select one of the five custom sizes.
    NOTE: There are five custom sizes that can be set up for use in the printer driver properties. Custom Paper Size can be given an individual name by selecting [Name]and typing the name for the custom size, such as, envelope. The name will then appear as an option in output size.
    Three types of envelopes are supported:
Type for Envelope Metric Size Imperial Size Monarch 98.4 mm x 191 mm 3.9 x 7.5 Inch Commercial #10 105 mm x 241 mm 4 x 9.5 Inch DL 110 mm x 220 mm 4 x 8.6 Inch
  1. Enter the short edge and long edge values for the envelope size you are using. The driver will now show the new custom size as one of the choices in Output Size.
  2. Click [OK].
To set your printing preferences for the printer:
  2. Right-click on the printer you want to print envelopes and select [Properties] from the menu that will be displayed.
  3. Select [Printing Preferences].
  4. Select [Tray 5] (Bypass) for the Paper Source.
  5. Select [Heavyweight 2 (170-220 g/m²)] for the Paper Type.
  6. Select the custom size you created for envelopes for the Output Size.
  7. Click [OK] twice to exit the Printing Preferences and the Properties windows.
To print envelopes at the workstation using Microsoft Word®:
  1. Open your Word application.
  2. Select [File] on the top left of the toolbar.
  3. Select [Print] from the menu. The Printer window will be displayed.
  4. Select the printer that you will use to print the envelopes. This printer will use the same driver where you defined the custom paper size.
  5. Select [Close].
    NOTE:If you do not select the correct driver you will not be able to select the correct paper size in Page Setup.
To print envelopes at the workstation using Microsoft Word Page Setup:
  3. Select [Page Setup] from the menu. The Page Setup window will be displayed.
  4. Select the [Paper Size] tab.
  5. Use the paper size pull-down to select the paper size you defined in the driver. The paper size will be listed by the name you gave it in the driver setup. The default will be custom 1, 2, 3, 4 or 5.
  6. Make sure the orientation is set to Landscape and select [OK]. At this point edit the page with the information you want printed on the envelope.
  7. Select [File] from the toolbar.
  8. Select [Print].
To load envelopes at the printer:
Load the envelopes into Paper Tray 5 (Bypass Tray). The orientation needs to be long edge feed (LEF) with the flap closed and the flap side at the lead edge, and the print side facing down. The printer is now set to print on the envelope.
NOTE: Load a maximum of 10 envelopes into Tray 5 (Bypass Tray) at a time. You may be able to fit a few more depending on the envelope's thickness but do not exceed the max fill line on the tray. The envelope may wrinkle depending on its weight and stiffness. The machine is not designed to handle high-capacity production envelope printing.
Solutions for : How To Print Onto Envelopes From an Apple Macintosh Operating System (OS) 9.2 Using Adobe PageMaker 6.5 Solution : Print Onto Envelopes From an Apple Macintosh Operating System (OS) 9.2 Using Adobe PageMaker 6.5
  1. Make sure the envelopes are properly loaded in Paper Tray 5 (Bypass). Load envelopes in the tray with the long edge feeding first, the flap closed, and the print side face-down in the tray.
    NOTE: Load a maximum of 10 envelopes into the tray at one time. Do not exceed the MAX fill line on the tray. The envelope may wrinkle depending on its weight and stiffness. The machine is not designed to handle high-capacity production envelope printing.
  2. Select the [Auto size detect] button on the Paper Size screen on the printer if this screen displays after loading the envelopes; otherwise, continue with the next step.
  3. Create the document on the Mac.
    1. Open the PageMaker application, click on [File] on the toolbar, and select [New].
    2. For Paper Size, select [Custom].
    3. Enter the dimensions as 105 mm (4.1 inches) by 241 mm (9.5 inches).
    4. Click on [Wide] next to the orientation.
    5. Click on the check box next to [Double Side] to remove the check mark and deselect the feature.
    6. Click [OK] and then create the document.
  4. Print the document.
    1. Click on [File] on the toolbar, and select [Print].
    2. Select the PPD that matches the printer you are printing to.
    3. Select [Paper].
    4. For the size, select [Custom] and enter the Width as 105 mm (4.13 inches) and the Height as 241 mm (9.5 inches).
    5. Under Source, select [Manual Feed].
    6. Click on [Features], and then select [Portrait] for the Bypass Feed orientation.
    7. Click on [Print] to print on the envelope.
Posted on May 27, 2011
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
Xerox 6110 bad print at paper over 80g
you need to read the machines stats.the dos and donts of the machine
Dec 17, 2009 | Xerox Office Equipment & Supplies
Unable to print #10 envelopes on my Xerox WorkCentre 7675... I am using Microsoft Word and selecting the Bypass tray, but I'm still unable to print on these envelopes. Are there any other solutions?
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
Jul 31, 2009 | Xerox Office Equipment & Supplies
I can't seem to print envelopes on the xerox workcentre 7345. I fed the envelope into the bypass tray, configured the settings on the workcentre as well as the word doc, but it gives me an error 012-255....
There is a lengthy set up process to that. I would recommend going ot Xerox.com, then at the home page, click on Support and drivers. When you get to that page, type in 7345, then click on the support home page, once there type in envelopes and the step by step instructions are there.
You are correct, setting up envelope printing on that machine can cause you to beat your head against a wall. The machine settings and the driver settings MUST be set exact. And it may take 3 or 4 tries, even for a service rep to get it all correct. Trust me on that LOL.
But once set up, it does a nice job. It is just very picky. Personally, I think it is way over designed just to print an envelope.
May 20, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Can't Print Envelopes from the Bypass Tray
you have to tell the printer in the print que that you are using envelopes and what size envelope.
-Carl, please let me know if this helps.
Oct 29, 2008 | Xerox WorkCentre PRO 128 Copier
Envolope Printing
The XD100 has a manual feed on the right side of the device. You can slide the guides to fit the envelope. Use the envelope printing in your program and I believe you need to specify the size of the envelope in the driver. I think you want to feed the envelope face down (side to be printed down) to have it print on the correct side, but I could be wrong. One way to check of course, try it one way and if it prints on the wrong side, flip it over. There may be an image on the feed slot that shows which side to use.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Xerox WorkCentre M-24 Color Copier Logo
599 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
