Question about Philips Magnavox MWR10D6 DVD Recorder
Cannot set anything with the remote - Philips Magnavox MWR10D6 DVD Recorder
  • Philips Master
  • 8,457 Answers
Tries to clean out the batteries compartment like metal - + battery connections with a rag with some WD40 chemical to get rid of the rust and dries condent moisture.Wait like another 10-15 mins for the effect to take place,replace the remote with a new set of battery,it should be working again.If it still have the same problems,the remote control CPU chip it is dead,the remotes devices it is heavily dependent on it CPU chip.Try website like Remotes.com to buy another remote same as the original or very close compatible to the original remote.
Posted on May 23, 2011
I need the remote code for a Techwood twd fv2a. The remote died and I have a universal remote, but no codes to programme it with. I've looked everywhere online but can't find anything.
In this case, you need to post both the brand names and model numbers involved in your request.Simplest would be to buy a new replacement remote and you can start here:
Remotes.com
Also, there is no such thing as a 'universal' remote; they are programmed with known codes available at the time of manufacture and sets that come on the market later than the remote will not be covered at all or only incompletely.
Some (expensive) remotes allow downloading of later code sets for newer models.
Jan 13, 2012 | Televison & Video
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
We have a KDL-26U2000, the problem is the menu button doesn't bring up the menu?? When you press the button on the remote or the top of the tv the green light will flash so the tv must recognise that I'm...
Checking your remote can be done with any digital camera since they can 'see' the infrared light from them but I suspect the remote is working; generally, if they are emitting anything, it will be sending correct correct pulse trains.
Having the camera 'live' you will be able to see that the remote is working by aiming the remote at the camera's lens and pressing any button while watching the camera's LCD display. The output of the remote will appear as white or near white blinking lights.
> I've tried to reset to factory settings but when I've got into the service menu I can't input anything?
Often the service settings require entering some code (password) sequence to access factory settings and it may not be possible to enter the code if one or the other end of the IR system isn't functioning.
Summary; I think the remote transmitter is OK but the receiver in the set is not decoding the received signal despite it indicating that something was received.
I think the set itself is a fault and you will need a tech on site on in the shop to search for the right board to replace since the IR receiver may be part of the main board (expensive) or a separate assembly (somewhat less expensive).
Jan 01, 2011 | Sony KDL-26U2000 26 in. LCD Television
Can't program Emerson Jumbo universal remote to Olevia TV.
they are set specific. you cannot use anything but the remote that came with it. before olivia went bankrupt if you lost your remote or had a main board replacement a new remote came with the board.
Mar 12, 2009 | Olevia 332V LCD TV
Remote control for Sony DVD recorder RDR GX3
I just replied your question about remote.
Please click HERE to see.
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
SAP on Mitsubishi Medallion 65" 1080
Set the tv to stero setting this should turn sap off. This can be changed by the remote or in the enu under audio settings. MONO<STEREO<SAP are some of the choices select stereo.
Second[ary] audio program[ming] (SAP) is an auxiliary audio channel for analog television that can be broadcast or transmitted both over the air and by cable TV. It is often used for an alternate language. HOPE THIS HELPED GOOD LUCK AND THANK YOU
SAMUEL
Jan 05, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Old tv remote control
in our universal remote that you tried if you have thr manuel in there look for manuel code entry cheers
Jan 18, 2008 | Televison & Video
Philips Magnavox MWR10D6 DVD Recorder Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
