Question about Cameras
I have Fuji F-650 The lens stuck and can not move in and out, the LCD said "error" whot can I do in order to solve it, Thanks.
    Sergeant:
    Champion:
  • 271 Answers
Sometimes there can be somthing stuck between the lens..very tiny objects can do so..else yu ar havin a problem with the cam program
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Posted on Aug 15, 2008
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
Hi! My camera is a fujifilm finepix S5600, and appears now on lcd screen "Focus error".. Can you help me solve this problem? Cumpliments Hugo
Hi Usually on your camera problem, tech just want to change the lens unit assemble. However, it is repairable, your local repair shop would charge around $65 to 145 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
Hi, I have cannon powershot 590. My camera is in the lens extended position and are not moving into the camera, There is a message on the LCD screeen "lens Error". Please guide me to solve the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 20, 2011 | Canon PowerShot A590 IS Digital Camera
We have a message coming up saying "zoom error"
If the camera was operating properly before the zoom error then the most common problem to a stuck lens is dirt getting stuck between the two lens barrels. There are a few fixes for this none are guaranteed to solve the problem and should not be attempted if the camera is under any type of warranty. They include removing the batteries for a few minutes, reinstalling the batteries with fresh once with full power, turn the camera on while holding the the zoom button. Another method is to see if you can provide extra power to the focus motor by having the LCD screen turned off. There my be a button that allows you to switch from the viewfinder to the LCD screen switch to the viewfinder and try several times to focus (just point the camera at different distant objects) and attempt to focus the camera. I hope this gives you the results you need because the other suggestions may further damage the camera and are only a (last resort) thing. One is with the camera turned on tap the body on a counter or table edge while trying to zoom the lens obviously in the opposite direction to where it's stuck. The last is to gently push the lens in with the palm of you hand while zooming in. All these are just suggestions and carry no guarantee of working and may further damage the camera. The biggest cause of this problem is dust from a camera bag or some other environmental condition like sand from a beach.
Jan 24, 2011 | Fuji FinePix S1000FD Digital Camera
Always shows not initiated on LCD
Either the camera is having a battery problem, or a lens issue:
Here are a couple sites that explain what you can do to try to correct this:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Even though the article is entitled "lens error", it also applies to stuck lens issues.
Good luck, hope this helps, and thanks for using FixYa.
Sep 16, 2010 | Fuji FinePix A120 Digital Camera
I have a fuji finepix S1000FD camera and it wont function. The screen has gone blue and there is a message saying zoom error. Have taken batteries out and left for a while ... tried this a few times,...
will the lens move in and out as normal? or is it stuck?
If it will move then the internal lens assembly has a problem.
If it won't move then that is causing the problem.
Will require internal inspection by someone who knows cameras
Dec 11, 2009 | Fuji FinePix S1000FD Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Digi camare
The lens on your camera has become stuck due to being dropped, contamination such as sand, or a malfunction within the lens. If gently manipulating the lens itself does not free it then you will need to get it professionally repaired or replace the camera. David Millier Advance Camera Repair
Feb 07, 2007 | Fuji FinePix F401 Digital Camera
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
