Question about ViewSonic VX922 19" Monitor Flat Panel
VX922 only shows "No Signal" on black screen
    Scholar:
  • 56 Answers
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
Posted on May 23, 2011
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
VGA: signal out of range on Dell1800FP. I see this type of card MSI PM8M3-V (7211010VPM8M3V) Motherboard installed. I know nothing, but would connect on Vga a Dell1800FP. Message : signal out of range
You need to lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution to 800x600. You mave to do this in Safe Mode by pressing F8 during boot.
Sep 30, 2012 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Viewsonic VX922 19" - green
Since you hadd confirmed that the monitor is faulty with a swap then it seems that the input signal processor is faulty.
Only a signal test will confirm the fault in the stage , so check from the power supply section to see if the set has tripped off due to a protection- if so check the output drivers.
Jul 27, 2011 | ViewSonic VX922 19" Monitor Flat Panel
I have a Viewsonic VX922 My led power goes on and off and the screen flickers then finally screen is black.
Defective power board can cause of on and off the led power, the boated electrolytic capacitor of secondary power supply and inverter area, shorted semiconductor of inverter area. The electronics repairman can fix this.
Sep 20, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Green light flashing on and off and computer screen will turn on when feels like it
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is YouTube video (do a search) showing how to disassemble the VX924 (very similar to the VX922) and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.
Feb 28, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Two problems vx922 Black screen of Death and vx910 no power
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
Nov 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 - black screen of death and the blinking (mocking!) green led
Really if this happens then you may want to contact viewsonic to see if it still in warrant. Reminder that most of their monitors have a 3 year warrany from the date of purchase. So make sure that you have your proof of sales/receipt/POP/invoice or what ever you want to call it ready. This model is old so they will ask for it if its a first time repair.
Oct 28, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic Monitor problem, blinking LED light, no picture.
you guys......you don't have a software (driver, refresh rate, etc.) problem. When you first power up the monitor, do you get any display at all (ex, "analog input" or "No input signal")? Of course not - that's because you have a hardware problem with the monitor. Go here and watch the youtube video on how to take apart your monitor and find and replace the "domed" capacitors that have blown:
http://www.tomshardware.com/forum/247964-33-viewsonic-vx922-monitor-black-screen-green-power-light-flashes
Fortunately I only had 1 ($1.76 at Radio Shack). I replaced it in less than 30 minutes and my monitor showed "no input signal" upon powerup as expected because I wasn't connected to my pc which is full of all kinds of drivers and refresh settings, etc.
Aug 16, 2007 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX922 19" Monitor Flat Panel Logo
159 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
