The LG Shine will only save messages to the SIM card after the internal phone memory is full (150 messages). This all happens automatically, and as far as I can tell, there is no way to force the phone to choose. Also, note that the SIM card will only store 30 messages. You can select the options menu
You can copy all your contacts in the sim card by going to contacts -> settings -> and copy all the contacts to your sim. Other information or data can be copied to memory card only.
Turn off the phone.Take the battery and Sim Card out.Make sure there is no dust or dirt of where the Sim Card goes.Blow air (from your mouth) of where the Sim Card goes.Sometimes rubbing a soft pencil eraser on the Sim Card contact points can help. Then place the Sim Card back in the phone.Make sure it is in the right position; copper contacts facing downward.Put the battery back in your phone.Turn it on, and see if the smartchip rejected goes away. If not you may need to contact your Phone Provider’s Tech Support to troubleshoot and confirm that you may need a PUK reset code to register or you may need a new Sim Card, as they do fail from time to time.
turn the phone on remove the battery cover and remove the battery while the device is still powered on then proceed to remove the sim card and clean the contact surface well with a dust free cloth replace sim card battery and cover. if problem persists contact customer care
The puk code is for your sim card. If you enered the incorrect code 10 times or more you sim card has been fried it will have to be replaced. My son had the same thing happen to his phone. We had to replace the sim card
