Question about Haier HDN655E Dehumidifier
Hauier dehumidifier HDN305 suddenly won't turn on. No motor goes on and no red or green lights go on either. It's properly plugged in to a functioning electrical outlet which has a functioning breaker that is on, and the water tank is properly in place. There is no reset button on this model.
    Brigadier General:
  • 4,736 Answers
You have already checked everything I would have suggested, so the only other thing I can think of is the temperature in the room, may be affecting it. If the ambient room temperature is above 112 degrees or below 32 degrees, the unit will shut OFF and not restart, until the temperature is within that range.
If you continue to have problems starting the unit, contact Haier America Customer Support 877-377-3639.
Hope this provided some help to you.
Posted on May 24, 2011
Why is the red water full light on and not worrking?
Usually, when the red water full light glows, it means that the water collection bucket is full & needs to be removed and emptied. Once that's done and the bucket is reinstalled properly, the red light will go out and the unit will turn back ON.
Jul 07, 2011 | Daewoo DHC-400 Dehumidifier
Has been running fine. my daughter emptied it yesterday morning and didn't put the catch container back in the machine properly and a red light (small round) on top left of machine was on when I went...
Actually, the fan shouldn't be working if the water bucket is not installed properly. So, I believe it's more of a case of the electronic controls need to be reset.
To accomplish this, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes.
After the time as elapsed, plug the unit in and turn the Master ON/OFF Switch to ON. The Bucket Full light should not, now be ON. And the unit can function as it should, after you reset the controls for maximum humidity extraction (32 - 35%).
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Danby DDR586R Dehumidifier
The bucket full light won't go out and the
Try resetting the bucket, making sure that it is set properly and triggers the safety lever/switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit from the wall outlet and wait 12-15 minutes. Plug the unit back in and turn the Master ON/OFF Switch to ON. If the bucket is installed properly, the unit should revert back to the original factory settings.
Hope this helps solve the problem.
May 28, 2011 | LG Dehumidifiers
Flashing green light stays on, unit won't start when you press the on/off button
I believe the unit needs to me reset to the manufacturer's default settings. To do this, turn the Master ON/OFF Switch to OFF and unplug the unit from the outlet for 10 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. The green light will blink until you change the humidity setting to below what the humidity level is in your home. If you set it higher, it will not turn ON or will turn ON only for a couple of minutes.
Also, check the position of the water collection bucket, to make sure that it's installed properly and has triggered the safety device.
To help you more, I have included a link to your Owners Manual that you can download and print for future reference, if you have misplaced yours. Take good care of your unit and perform routine maintenance regularly. As Danby has discontinued (retired) your model humidifier.
http://www.danby.ca/cms/uploads/products/en_manual/DDR4007EE2.pdf
Hope this helped you. Please let me know. Thanks.
May 06, 2011 | Danby DDR4007EE Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
I have a Haier HDN305 dehumidifier. It just sopped working and will not turn on. Can you help me?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 15, 2011 | Haier HDN305 Dehumidifier
We just got this dehumidifier in a garage sell, and it runs, but we see no water in the basin. We have run it for over an hour now, and we were wonder if it's working properly. The fans is working, and...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Sep 26, 2010 | Haier HDN305 Dehumidifier
Haier HDN305 dehumidifier does not pull moisture from air and does not collect water in bucket
heatman101
Jul 26, 2010 | Haier HDN305 Dehumidifier
Fan running
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 12, 2010 | Haier HDN305 Dehumidifier
I would liket to obtain an owner's manual as I have lost mine. Model HDN305
I have spoken with the folks at Haier. They have all current manuals on line for immediate down load. If yours is "classic" (read OBSOLETE), send em a e-mail and they will send you whaat you need.
I received great customer srvice from them.
Oct 05, 2009 | Haier HDN305 Dehumidifier
Haier HDN655E Dehumidifier Logo
347 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Vincent Cruz
Shehu Pro
Shehu Pro
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
