Question about Briggs & Stratton Garden
I have a Murray Select 42 inch with 16 HP Briggs and Stratton. The riding mower is about 11 years old. The transmission is a "shift and go". I am having problem going forward when on an incline and it will slow down and/or stop. I can shift into reverse and back down and then jack with the shifter until I can get the transmission to "catch" and try to continue, but it is clearly getting worse.
    New Friend:
    Problem Solver:
  • 9 Answers
One you need to look at your belt it is MST box do jack with it as you will bust the transmission your pulled may need look at a long with your belt you can ring me on 07849461942 I am in north Leeland thanks
Posted on Sep 23, 2017
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
SOURCE: murray riding mower 12.5 hp briggs & stratton
Where could I buy a new gas tank for my Murray 12.5 riding mower? Has a Briggs & Stratton Engine?
Posted on Apr 07, 2010
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
I need the three bolts that attach the motor to the deck on my 42" 14.5hp Murray riding mower and I am not sure of the size without taking opne of the old ones out. Do you have online a manual for...
There are websites like or that allow you to enter your mower's model number and you can bring up an illustrated parts drawing, look at those and it will have the numbers and if you are lucky even the sizes. May be able to find on Murray website also the same drawings.
Note if older than 1993 you may not find drawings anywhere, I have not been able to yet for my 1993 Murray 14.5 Hp 42" riding mower.
Also if the engine is the origingal and it is a Briggs and Statton, to find the manufacture date of the mower look for the model-type-code number on the shroud. Sometimes it is stamped sometimes it is on a plate. The last sequence of numbers is the date code. It starts with the last two numbers of the year, followed by the two digit month, then the two digit for the day and then a few other numbers after it. So if the date code is 010427xxxx then the motor was manufactured in 2001, on April 27th. This is the easiest way to get an approximation of a mowers age, if original engine and it is a Briggs and Stratton.
Jul 08, 2011 | Briggs & Stratton Garden
I can't find any thing on my my riding mower
This machine was made by Murray who is no longer in business. Briggs and Stratton purchased a majority of the company and a lot of the parts can still be purchased through Briggs. I do not see a parts diagram for the (b) series but I was able to find one for an (a) which is a year older machine. I have included a link for the parts diagram of it. Murray 425614A Murray 42 Lawn Tractor 2002 Diagrams and Parts List...
Jul 14, 2010 | Briggs & Stratton Garden
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
May 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
