Question about Stanley Bostitch Mcn150 Strapshot Metal Connector Nailer
Head valve seems to stick during firing of the tool All new part in tool I have 5 tools with same problem mcn150
    President:
  • Stanley Master
  • 1,388 Answers
#1 If the gun only releases air from the trigger and does not fire, suspect orings on Headvalve leaking. Easy to check, remove head and Headvalve and examine the surface in head where oring makes contact with metal surface. If the metal surface looks worn / fine scratches, air is leaking past and gun will not fire. Remove fine scratches with 400 grit paper. Headvalve oring must seal or gun will not fire. If the Headvalve does not make tight seal with new oring, remove new oring and wrap some teflon tape into groove and reinstall oring. The teflon tape will make the oring fit tight against metal surface (try 1 1/2 loops of tape).
#2 If the gun fires however the headvalve gets stuck in the head after some use, Headvalve spring could be weak. Replace the spring or remove the spring and add spacer below spring to give more pressure (I use oring with same diameter as spring under the spring ).
Use silicone paste lube on all orings and surface where orings make contact. This paste is sold at Lowes in the plumbing department and swimming pool supplies. When you connect air to the gun, listen carefully for leaks out the nose or head. Slight leaks will affect how the gun works. Repair as needed. Good luck with your repair.
Posted on May 27, 2011
LOOKING FOR SEAL REPALCEMENT AT TOP OF PISTON
Search Results
    [PDF]How to Repair you Nailer - Master Tool Repair
    www.mastertoolrepair.com/.../How%20to%20Repair%20you%20Nailer....
    Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
    Rebuild a Framing Nailer ' The Family Handyman
    www.familyhandyman.com/tools/air-tools/rebuild-a...nailer/view-all
    Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
    FASCO - Frequently Asked Questions - fasco tool finder
    www.fasco-tools.com/en/faq-manuals.html
    Search Tools by Application ... My Fasco pneumatic nailer/stapler leaks air from the
Feb 09, 2016 | Air Tools & Compressors
Changing exsaust valve and valve guide on a Kohler 12 horse engine.how do I remove the guides.
you will need 3 special tools for this job . remove the head and valves . One tool will be turned so that it fits in the guide and is slightly smaller than the guide outer diameter. The other tool will go around the guide and rest on the valve spring seat. This allows the guide to be pressed out without stressing the head . The third tool will fit in the guide and will be recessed so that it slip down over the guide the required distance so that when the guide is pressed in the outer edge will hit on the valve spring seat and position the guide in the correct distance into the head. The tool that was used to go around the guide to press out will be used in the head chamber to support the head during the pressing in process.. I would rather take the head and the new guides to an engine re-conditioner shop and have the job done in 15 minutes so that I could then get then to seat the valves in the head properly
Jun 05, 2014 | Cars & Trucks
Briggs and Stratton 23 hp lawnmower engine exhaust valve keeps sticking
it is possible that the valve stem is bent or has a build up on the stem that is jamming in the guide. Pull the head and replace the valve.
Sep 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Want to build old cylinder head parts into new cylinder head on a colt 2.8 rodeo 2001 model double cab
if you are using the old valves in the new head you will need to seat the valves into the new head,the best way to go is to take it to a mechanic and get the valves seated in properly ,and you can also get the springs checked as one or more could be weak but you can seat the valves yourself by getting valve grinding paste and a valve grinding tool a stick with a suction cup on it then you turn it in your hand clockwise and anticlock wise.
Sep 20, 2013 | Motorcycles
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
Won't Start, back-fires through carburetor, took off sump cover and camshaft lines up correctly with crankshaft but exhaust valve is loose and doesn't have any tension when cam lobe is on the flat side....
I once made a valve spring compression tool out of a sliding bar clamp from my woodshop the ones with the flat bar the clamp slides on not a pipe clamp because it wont let you close enough. then I ground a U shaped slot in the stationary head to allow it to slide over the valve stem then you can crank the other end to compress the spring
Mar 15, 2017 | Garden
My eu1000 started using oil. The compression seems fine so I took off the valve cover. The valve guides seem worn. How do I get them out so I can replace them?
We soak the cylinder heads in hot oil for several hours to get the head heated enough to use a a specially designed tool to remove the valve guides. (see below) Even then there is the possibility that some re-surfacing / material build up is required that will result in the valve seat having to be removed also. It will be nearly impossible to remove it in someones garage without runiing the cylinder head and valve seats. Most automotive machine shops will do this for you if you carry it in. I do recommend that if you do take it to a machine shop that you have the valve seats re-ground. We had all of the tools to do this but never removed a valve guide on a cold cylinder head.
Valve guide removal tool:
http://www.speedwaymotors.com/Valve-Guide-Removal-Tool,2629.html
A tool like this one is often required to remove valve guides:
http://cgi.ebay.com/ebaymotors/GO-KART-BARSTOOL-RACING-ENGINE-VALVE-GUIDE-PULLER-KIT-/250507189301?pt=Race_Car_Parts&hash=item3a53645c35
See the link below (although link is related to a full size engine, the process is the same):
http://www.ehow.com/list_6610338_valve-guide-removal-tools.html
All I will say is one wrong step and you can easily have the need for a good machine shop or a new head.
Thanks for choosing FixYa.
Kelly
Oct 07, 2010 | Garden
Piston will not retract fully once fired
sounds like the tool needs to be cleaned and serviced or the driver is bent, if you don;t have the owners manual to clean this tool, go to Paslode.com and type in your model number for a detailed instruction on the cleaning of the tool.
Jan 14, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Bent push rods both cylinders,engine # 445677-0827-B1
You can find a manual, free of charge at www. briggs & stratton.com. click on manuals and put in your model and type and its free to d/l. You can then print it out if so desired.
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Stanley Bostitch Mcn150 Strapshot Metal Connector Nailer Logo
269 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
