Question about SanDisk 32GB Ultra Backup USB 2.0 Flash Drive - 32 GB - USB - External Hard Drive
I have a sandisk cruzer blade 32gb usb flash drive and when i put some data on it, it asked if i want to format,,,,obviously no because i just put the data on but afterwards i cant open it without it bringing da "do u want to format it?" so i format it and try to put ma data back on but now important parts of my data keep on missing like i put a 5gb folder, its now a 700mb folder......help????
  • SanDisk Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive hope this helps
Posted on May 23, 2011
  • Brian Sullivan
    Brian Sullivan May 23, 2011
    check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
    scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
    select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
    hope this helps
  • 805 Answers
You may have formatted the drive in NTFS instead of FAT32. if its an old version of Xp or Win98 then it may need to be formatted in FAT32. If its windows 7 then it must be in NTFS. in My computer right click on the icon for the drive and left click on format. You should see the options for with type of file system you want.
Good luck
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: i have a sandisk cruzer
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
((I have found better results ticking the first box then reurn and tick the second box)) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you can do these in in any order it will dependend on administration rites
hope this helps you
Posted on Sep 03, 2011
I just want to format my Cruzer Glide 32gb scandish. Regular format no security.
Do you have a PC? On a Mac, open disk utility. Select cruder glide from list. Go to format tab. Reformat to MS-DOS (FAT)
Oct 16, 2013 | SanDisk Cruzer Glide - USB flash drive -...
My16gb sandisk cruzerblade pendrive asking formatt. but it did't formatted.
You will need to format it.
Video on How to Format.
Dec 17, 2012 | SanDisk 16GB Cruzer Blade - USB Flash...
How do I remove a password from a SanDisk Cruzer Switch 32 GB USB Flash Drive
Here is a "How to" article describing how to remove the password (if you know the password.
http://www.ehow.com/how_8120645_password-off-cruzer.html
Here is a SanDisk article for retrieving the password if you don't know it.
***Caution potential data loss****
http://kb.sandisk.com/app/answers/detail/a_id/800/~/retrieving-a-forgotten-password-on-a-cruzer-enterprise-drive
Oct 27, 2012 | SanDisk Cruzer Switch 32GB USB 2.0 Flash...
Cruzer blade not recognised by sony car audio
Dear Friend,
IMPORTANT!: Save all your data first then, uninstall the U3 Software then, Format the drive to FAT32, pass all your data back to your thumb drive and try in your car radio. If the problem persist, try to format it to NTFS format.
Good Luck!
Jan 07, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I have a sandisk cruzer blade 32gb usb flash drive and when i put some data on it, it asked if i want to format,,,,obviously no because i just put the data on but afterwards i cant open it without it...
also
Click permissions
hope this helps you
Sep 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
SanDisk Cruzer Blade is not showing data. The drive shows up in 'My Computer' but data is not showing.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I used my sandisk cruzer 8g as a first boot device to load a certain application, then suddenly hangs and power off, after i restart the pc my usb device reads as 0 data, when try to open it asking to...
Hi Amir,not 'Safely remove the hardware' will result in data loss on USB flash drive.However,you can recover your data on it with third party data recovery software.I have succeed to recover data from pen drive with Tenorshare data recovery.It can recover data after deeply scanning your USB flash drive to look for lost data. By the way,you can download a trial version and scan your flash drive for free to preview whether your data can be recovered. http://www.any-data-recovery.com/index.htm
Jun 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My SanDisk Cruzer USB flash drive had problams with the U3 systam, So i uninstalled it by using the "renuve u3 luntch pad.exe." then I selected the "format adn keep my data" option, but the systam find a...
You have ruined the file integrity of the flash drive, There is a very slim chance that you will recover any data off of the drive. Most flash drives only have a read/write of about 8,000 to 9,000 times so depending on how much you actually used the drive, it is possible it finally went bad. To format the drive try going to my computer and right clicking on your cruzer drive letter and click format. "ALL DATA WILL BE ERASED WITH THIS OPTION"
Jun 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
32gb Cruzer USB light comes on when i plug it into (any USB port) message = "New Hardware found" but i cannot access the (E) drive thru my cimputer...it ask me to insert a disk...... its been fine...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 25, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problems with SanDisk 4GB Cruzer. looks good at
Okay, Can you tell me the model of your computer?
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
May 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 32GB Ultra Backup USB 2.0 Flash Drive - 32 GB - USB - External Hard Drive Logo
1,419 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
