Question about Honeywell Dryers
I have a dirty Duracraft DW627 twin window fan. There is no way to really clean it from the outside and so I'm trying to open it up and separate the two halves so I can wash the screens & wipe the blades. I've unscrewed the 12 screws holding the two halves together, however, the off-hi-low levers (found on both sides) are located right between the two fans (you can kind of see one in the photo on this page: http://www1.epinions.com/content_74005122692) and prevent me from completely separating the two sides. I'm flummoxed on how to get this apart so I can clean it. I've had the same problem with other twin window fans and it really annoys me. This fan works just fine but it's so dirty (not only dust but there's a few gnats that met their demise on the blades) that it's embarrassing to put into our window. The manual is pretty useless as it says I'm to clean it by wiping the exterior with a damp cloth.
SOURCE: cleaning of the fans
When I called Seville Support I was told that you can NOT open fan to clean and may not get it together if attempted (glad I stopped when I did!).
You need to use air pressure. After using much of a can of compressed air such as you would use on a keyboard and not getting too far, I broke out my seldom used air compressor which kicked out enough dust bunnies as to block out the sun. Hint: be sure to use outdoors. I'm happy to report both units working as good as new.
Don't have an air compressor? Ask your neighbor, he'll need the correct nozzle to 'blow air' (it comes in handy for many tasks).
Posted on May 14, 2010
catriver
  • 878 Answers
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
Posted on Sep 18, 2006
jsrock516
  • 5911 Answers
SOURCE: black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Posted on Jul 06, 2007
  • 1122 Answers
SOURCE: condensation inside empty clothes dryer
yes,also if you have a front load washer you do the same thing,hope this helps-mike
Posted on Jun 16, 2008
SOURCE: Oscillation works but motor doesn't
I have the very same model and it worked for 6 years OK. Two days ago the fan stopped turning even tho it still oscillated.  I often repair my own equipment and so I opened it to check what was wrong.  I found out that it has two motors., one for oscillating and one to turn the blades.  In short I discovered that the fan motor is bad, even though there was no odor.  Using duct tape or glue is not a solution unless you hear noise from the motor when your fan is on and the oscillating off. I suggest that you return your unit if it is new..   Personally I am going to try to purchase a new one if I can find the model.  I hope this helps.
Posted on Aug 16, 2008
Duracraft DW627 twin window fan. Need to open case to clean inside. Have removed 12 screws holding the two halves together. The off-hi-low levers prevent the halves from separating. Please help!
what i do with mine is take it outside and hose it down with simple green cleaner. let it sit a few minutes and blast it clean with water.let it dry well before you plug it back in. i do this once a year. hasnt failed me yet.
Jul 21, 2017 | The Computers & Internet
I am. Trying to clean a duracraft 1997 but i. Cant get the blade to separate. From the motor
Some of them are not meant to be seperated, if it is, then it should have 2 slots opposite of eachother in the back of the blade where the plastic fan meets the steel rotating bar, or it could just be pressed on and you would have to pull it off with as much equal force all around the circumference of the back of the fan's main part, the entire round part, either way you need at least 3 hands to do the job, so have someone help you or just clean it as good as you can as it is, I don't think it really needs to be that clean aye'? LoL
Nov 16, 2016 | Duracraft Dryers
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
Just trying to take the plastic covering off of the motor without breaking the plastic controls off
The speed control knob will pry off with a thin screwdriver. Once you have removed it, you will see that the knob for the oscillating feature is split where it slides over its shaft. I took a jeweler's screwdriver and separated the halves slightly and the knob pulled free. It's made that way so it doesn't pull off when you go to turn on/off the oscillation. If you're going to oil the rear of the motor, be really careful when you remove the rear housing and separate the motor sections. The winding wires are tiny andfragile. Only take it apart as far as necessary and be careful reassembling the unit. Hope this helps...!
Sep 22, 2011 | Duracraft DS-1600 Fan
Hi, we have a Duracraft Commercial Grade High Velocity fan. When we turn it on it just hums, fixable? thanks, Nancy
Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
Sep 01, 2011 | Duracraft DS-1600 Fan
Hi, I have a Duracraft commercial model fan it sits on a metal stand about four ft high with a round base. The on/off switch is housed in a black box screwed to the fan base and then a wire runs up into...
A short circuit in the power wiring would probably cause the fuse or breaker controlling the circuit to open. Make sure the AC outlet you're plugged in to is actually working. If so, there's an open circuit somewhere if no power is reaching the motor.
Have you checked the switch with an ohmmeter to make sure it's really working? Check the wiring from the switch to the motor. You can also make sure the motor windings aren't open with the ohmmeter. The motor may have burned out as they sometimes do.
Check for voltage right at the motor. If this is a brush-type motor, the brushes may be worn out. It may also be that the motor is getting voltage but has a bad starting capacitor. Most commercial equipment uses capacitor-start motors, and the capacitor is usually mounted in a bracket on the motor. You can test the cap with a meter that has capacitor checking; replace the cap if it measures outside of the tolerance marked.
Aug 07, 2011 | Duracraft DS-1600 Fan
Fan motor gets very hot and wont start till it cools
this might be a power problem or very dirty in side motor if cass get a can of air and clean it really good , or you have to much power coming in off your plugin you can get a meter and test it it should read between 118 123 volts good luck if it reads much more you found your problem get a elect to fix it. good luck
Jul 29, 2011 | Duracraft Dryers
Have a Duracraft DT-70. It is dirty and filled with cat hairs and grease on the blades. I can't figure out how to get it apart to clean it.
You will need to take this apart and use a good degeasing spray to remove off al the dirt. Use diesel/kerosene to wash well and clean it dry. Use a good paintt brush to wash off all dirt into the hidden areas.
Wipe dry finally to reset.
Sep 13, 2010 | Duracraft Dryers
Replacement Blade Knob for Duracraft Table Fan Model No.DFT-218W
I thought the same thing. It was hiding in one of the stryfoam pieces.
May 01, 2009 | Duracraft DFT-218W Table Fan
Can't get at the fan to clean
You cannot do it as it need a specialist's skill.What i do is to insert a bubble tea's drinking straw and insert it into a vacuum cleaner's attachment that is formed like a **** and attach the other end into the grills of the device and gently vacuum the dust away.Good luck.
Apr 14, 2008 | Duracraft DCM200 2 Gallon Humidifier
Dryers Logo
1,256 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
