Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven will not light in bake mode but will light when in broil mode
  • GE Master
  • 2,605 Answers
Hello, welcome to FixYa.
Based on your description, I`d suggest the hot surface ignitor for the bake burner is likely the problem. Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined.
It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
since your boiler has the same ignitor ( some do some don't, only a model number would confirm or dismiss this...thankfully you provided yours ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case.
Many people overlook the ignitor, especially if it "glows" since that gives the untrained person the impression it works...that is not the case however.
You can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake & broil ignitor. The number I got based on the premise it is a JGBP90 model is part # WB13K21
I would still double check with your model number with the part`s professional`s.
Hope that help`s. It is very unlikely to be the control panel/timer contrary to what your repairman has said...in my opinion. Let me know if I can assist you further and good luck.
Thank`s for visiting "fixya" for your repair needs.
Regards,
Macmarkus :)
Posted on May 23, 2011
5 Suggested Answers
huuum
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Posted on Oct 16, 2008
  • 107 Answers
SOURCE: JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Posted on Mar 14, 2009
  • 23 Answers
SOURCE: Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Posted on Sep 18, 2009
  • 713 Answers
SOURCE: Oven's bake funktion does not work
Hi,You need to replace the oven igniter. You will find that this is a very common problem with that model and other models that use this igniter. It is very simple to do.
Look inside the oven and you will find 2 screws at the bottom of the oven in the back. Loosen them up and remove the bottom panel of the oven.
Remove the broiler, and oven trays and it is a 10 minute swap out. Removing the above items allows you the access needed to get to the two screws that mount the oven igniter to the burner.
Using either a socket (1/4") or a nut driver, remove the 2 screws and unplug the igniter. The most difficult part of the exchange is unplugging the igniter. The plastic will most likely break because it has become very brittle by being exposed to the heat. Be careful to break only the part that is being replaced.
If you do happen to break the fittings, they can be replaced with any male/female connector. If you need to replace this, I recommend that you stay away from plastic encased plugs.
You then install the ingiter, plug it in, and you are back in business. It is a very simple part to replace, but it is costly.
Thanks and take care
Posted on Apr 27, 2010
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
Feb 01, 2011 | Kenmore 33169 Gas Single Oven
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Oven stays in warm up mode
does broil work? if broil works and bake does not you have a bad bake element. let me know how it goes
Jun 14, 2009 | Frigidaire Ovens
Stuck in broil mode
sounds like you need to call MAYTAG repair service ,control board has probably failed .we do not recommend DIY fixing of any gas appliance.
Feb 15, 2018 | Ovens
Hello stevefer
Welcome.
First,
Huuum
Oct 16, 2008 | Kitchen Ranges
Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,010 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
