Error e000020-02a9 canon ir3100cn - Office Equipment & Supplies
pineworks
  • 4041 Answers
SOURCE: IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Posted on Feb 16, 2010
SOURCE: Cannon IR3100CN - error code E000020 - 0081
it needs a new photo drum unit.
Posted on Feb 29, 2008
SOURCE: canon iR3100CN error code
do you have the installation or user guide for this printer?
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
fer_nan_14
  • 76 Answers
SOURCE: Error code
HI
Machine error E0020-01a9 is developer problem
Posted on Dec 13, 2008
fer_nan_14
  • 76 Answers
SOURCE: canon ir3100cn
check your itb home position, are you sure for that error # e0072? maybe e0070
Posted on May 21, 2009
My canon ir3100cn displays "finisher
My canon ir3100cn displays "finisher can not be used" with on screen. i'm using saddle Q2 finisher. it doesn't move at all.
Sep 03, 2011 | Office Equipment & Supplies
Canon IR3100CN error message E000732-0001
Found a defective cable (FH2-7036-000) between Reader & machine causing error code
Sep 14, 2010 | Canon imageRUNNER C3200 Copier
I have a canon ir3100cn. smudging problem
Does the toner seem like it isnt "baked" enough?
If yes replace fixing assy.
Jan 26, 2010 | Canon iRC3100 Printer
Showing error code E000020-01a9 on IR 3100CN
this code is for the density of the yellow toner, most likley has a bad drum.
Aug 13, 2009 | Canon Office Equipment & Supplies
Canon IR3100CN E000070-0002 During start up the code pops up and the copier don't work.
you have a broken ITB unit,
its a pretty common error code on these machines, you need to replace your ITB frame and it prob has broken the belt also
Jun 04, 2009 | Canon imageRUNNER C3200 Copier
Canon ir3100cn
May 21, 2009 | Canon imageRUNNER C3200 Copier
Error code
HI
Dec 13, 2008 | Canon imageRUNNER C3200 Copier
Canon iR3100CN error code
Aug 18, 2008 | Canon imageRUNNER C3200 Color Printer
444 people viewed this question
k24674
jasbo
jasbo
