I have got windows xp on my computer but when i go on the start-programs(or all programs)like it is written in the note book a transparent icon appears in the left of my screen and it stays there. the icon won t move and when i want to end it another icon appers and tell mee that i have choose to end a nonresponding program and ask me if i want to send an error report.i send it a few times alredy but with one month of trying there is no change what should i do?
  • 27,725 Answers
Scroll to bottom of screen (task bar)right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes and users you will see who is using your computer
also you should uninstall a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
hope this helps
Posted on May 23, 2011
How to fix the backlight on a Iqon 8050qxx Laptop
To set the transparent background on the icons, we'll need to open System Properties in Control Panel (or right-click on My Computer and select Properties).
In this dialog, click the Advanced tab, and then the Settings button under the Performance section.
Now scroll down to the button where you'll find a checkbox for "Use drop shadows for icon labels on the desktop". Make sure you check this box if you want transparent backgrounds on the icons
Jan 20, 2014 | Microsoft Windows XP Home Edition
Tip
Transparent Desktop Icons
Turn your desktop icons transparent by following these steps:
Step 1:
Goto Control Panel.
Step 2:
Goto System.
Step 3:Click on Advanced.
Step 4:
Click on Settings in Performance Area.
Step 5:
Click on Visual Effects tab.
Step 6:Click on 'Use drop shadows for icons label on desktop'.
on Dec 17, 2009 | Microsoft Windows XP Home Edition
Tip
Make older programs run in Windows XP.
If you're having trouble running older programs originally developed for previous versions of Windows, you're not out of luck. Luckily for consumers, Microsoft built Compatibility Mode into XP. Compatibility Mode allows you to run a program using the shell of the original program it was developed for. Today Chris shows you how to access a program's Compatibility Mode in XP:
  1. Find the executable or program shortcut icon you'd like to run.
  2. Right-click the icon and select Properties.
  3. Click the Compatibility tab and place a checkmark next to the text labeled "Run this program in compatibility mode."
  4. Select the operating system that the program was originally intended to run on.
  5. You may need to fine-tune the three fields under "Display Settings" if an older program requires 640x480 resolution or 256 colors.
  6. Click Apply.
Try starting the program after making these changes. If it still gives you trouble, try a different operating system. If the program was written for Win95 and worked fine in Win98, there's nothing that says it still won't work fine with Win98.
on Jun 03, 2008 | Microsoft Windows XP Professional
CANNOT PLAY BICYCLE PINOCHLE SINCE UPDATING COMPUTER PLAYED BICYCLE PINOCHLE ON WINDOWS 98, CANNOT PLAY ON WINDOWS 7
Unfortunately, due to changes in the OS and how programs run, a program written for Windows 98 will not run under Windows 7 directly.
Even the compatibility mode will probably not work unless your version of Bicycle Pinochle for Windows was written for XP as well as Windows 98. (The WinXP version would possibly run under the Windows 7 32-bit version; it won't work under the 64-bit OS. To find your version of Windows 7, click Start > Control Panel > System and Security > System. If the version title ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version.)
You need to either upgrade your game software or get an older version of Windows running somehow. This could be a virtual computer (runs inside your Windows 7 computer if your hardware permits it), a second machine or a dual boot computer. For Windows 98, you will need a licensed version of the OS for any method. Check a nearby Windows User's Group to see if anyone there has the OS.
If your version of Pinochle could run under Windows XP and you have Win7 Pro or Ultimate (or upgrade to them), you can run a virtual version of XP for free. In this case, download and install (in order) Virtual PC and XP mode from Microsoft. Then install the software in the XP computer as if it were the only computer running. (The compatibility mode didn't work inside XP mode for software written for Windows 2K so I doubt a Win98 program will work.)
An XP version of Bicycle Pinochle was offered by Microsoft: http://www.microsoft.com/games/bicycle/card/ . A Windows 7 version of Single Deck Pinochle is here: http://www.sac-irca.com/pino.html .
I wish that I had better news for you.
Oct 23, 2011 | Expert Software Bicycle Pinochle for...
Is there any driver, program or software fix that will allow me to load my "Intel Create & Share Software on my Windows 7 Dell Inspiron 530?
The Intel Create & Share was written for Windows 2K and XP and not updated. The workaround is to use a computer (second machine, dual boot or virtual) with XP installed.
If you have Windows 7 Pro or Ultimate or update to one of those versions, you may be able to run a virtual XP computer for free. Download from Microsoft and install in order the Virtual PC program and the XP mode software. Install the Intel Create & Share program in XP mode as if it is your only OS. (Note: you can't have hardware installed on the virtual and real computer at the same time. To share files you will need to save them to external media (USB or optical disc).)
Other virtual computer programs are VMWare and Parallels. For the other options, you will need a licensed version of the older Windows OS.
I hope this helps.
Oct 09, 2011 | Dell Computers & Internet
No internet explorer
You have not mentioned the operating system .. plz mention it .. However generally you can open computer or my computer .. go to the c: drive go to program files and look for internet explorer folder .. in that folder you could find an icon which looks like IE but would be written iexplorer.. U can use this as your IE .. rt click send to desktop and you will have an icon for it in the desktop. you can rename it to anything you like once it is in your desktop screen..
May 31, 2011 | Microsoft Internet Explorer 7
I have XP Home,and for some reason,my volume control icon is missing from my taskbar.When I opened "Sounds and Audio Device Properties",and checked the "place volume icon in the...
Method 1: Add the Volume iconTo add the Volume icon to the notification area of your computer, follow these steps:
  1. Click Start, and then click Run.
  2. Copy and paste or type the following command in the Open box, and then click OK: mmsys.cpl
  3. Click to select the Place volume icon in the taskbar check box.
  4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2. uparrow.gifBack to the top Method 2: Save a new copy of the Sndvol32.exe file on your hard diskIf the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk. PrerequisitesThis method requires you to have your Windows XP installation CD.
Note If you do not have access to the Windows XP CD that contains the installation files, ask the network administrator for help if the computer is at your workplace, or contact Support. To contact Microsoft Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ (http://support.microsoft.com/contactus/) To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk, follow these steps:
  1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
  2. Click Start, and then click Run.
  3. Copy and paste or type the following command in the Open box, and then click OK: cmdThe command prompt opens.
  4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer's CD drive is drive E, type the following, and then press ENTER: e:
  5. Copy and paste or type the following, and then press ENTER: cd i386
  6. Copy and paste or type the following, and then press ENTER: expand sndvol32.ex_ system_root\system32\sndvol32.exeNote system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER: expand sndvol32.ex_ c:\windows\system32\sndvol32.exeNote There is a space between "ex_" and "c:\windows" in this command.
  7. Type exit to exit the command prompt, and then press ENTER.
  8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
If the Volume icon is displayed in the notification area, you are finished. If the Volume icon is not displayed in the notification area, go to the "Next steps" section.
Resource
http://support.microsoft.com/kb/319095
Jan 26, 2011 | Computers & Internet
Volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
mmsys.cpl
4. Click OK.
Prerequisites
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
cmd
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
cd i386
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
Hopefully the Volume icon is now displayed in the notification area.
Jul 18, 2009 | Computers & Internet
Sony driver update
You can down load the driver for vista of sony DCR- DVD 100E/DVD 200E from the following links
This chart provides compatibility information for software that ships with Sony digital cameras and camcorders.
Note: Not all software applies to all models. If uncertain, please refer to your product manual to determine which software came with your model.
Software Compatible Additional Comments Movie Shaker™ software Ver 3.1 for MICROMV camcorders No N/A Nero® Express 6 No N/A Pixela ImageMixer™ for HDD Camcorder No Please update to Picture Motion Browser Ver. 2.0.11
Note: This software is not applicable to all models. Pixela ImageMixer Ver 1.0 No N/A Pixela ImageMixer Ver 1.5 No N/A Picture Motion Browser Ver 1.1 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.0.01 – 2.0.06 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.1.00 – 2.1.01 Yes N/A Pixela Picture Package™ software Ver. 1.0 – 1.7 No Please update to Picture Motion Browser Ver. 2.0.13
Note: This software is not applicable to all models. *2 Pixela Picture Package™ software Ver. 1.8 No Please update to Picture Motion Browser Ver. 2.0.12
    *1 It is not possible to save RAW files in the SRF format with the Image Data Converter SR software.
    *2 It is not possible to create a Video CD using Picture Motion Browser.
    *3 Examples of behavior variances:
    Display -
    • The Picture Motion Browser short-cut icon may become a Windows-standard icon.
    • The tooltip information window may not be transparent.
    • images may not be displayed properly in the browser window while playing back movies.
    • Some images, character, and icons may not be displayed properly.
    Sound -
    • The volume control bar in the browser may not be operational when playing back movies.
    • While playing back movies the sound may not be output.
    Other -
    • Some folders, such as public folders, cannot be registered as Viewed folders.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
Mar 30, 2009 | Video Cameras
Toy Story Interactive Incompatibility
You could try this.
To run the Program Compatibility Wizard
  1. Start the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
clip_image001.gifNote
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
To set the compatibility properties for a program manually
  1. Right-click the program icon on your desktop or the shortcut on the Start menu for the program you want to run, and then click Properties.
  2. Click the Compatibility tab, and change the compatibility settings for your program.
clip_image001.gifNotes
  • The Compatibility tab is only available for programs installed on your hard drive. Although you can run the Program Compatibility Wizard on programs or setup files on a CD-ROM or floppy disk, your changes will not remain in effect after you close the program.
If this doesn't work you will not likely be able to play them.
Nov 12, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
