Question about Stanley Bostitch Mcn150 Strapshot Metal Connector Nailer
MCN150 Will not lift head valve to fire it - Stanley Bostitch Mcn150 Strapshot Metal Connector Nailer
2 Suggested Answers
  • 1388 Answers
SOURCE: head valve seems to stick
#1 If the gun only releases air from the trigger and does not fire, suspect orings on Headvalve leaking. Easy to check, remove head and Headvalve and examine the surface in head where oring makes contact with metal surface. If the metal surface looks worn / fine scratches, air is leaking past and gun will not fire. Remove fine scratches with 400 grit paper. Headvalve oring must seal or gun will not fire. If the Headvalve does not make tight seal with new oring, remove new oring and wrap some teflon tape into groove and reinstall oring. The teflon tape will make the oring fit tight against metal surface (try 1 1/2 loops of tape).
#2 If the gun fires however the headvalve gets stuck in the head after some use, Headvalve spring could be weak. Replace the spring or remove the spring and add spacer below spring to give more pressure (I use oring with same diameter as spring under the spring ).
Use silicone paste lube on all orings and surface where orings make contact. This paste is sold at Lowes in the plumbing department and swimming pool supplies. When you connect air to the gun, listen carefully for leaks out the nose or head. Slight leaks will affect how the gun works. Repair as needed. Good luck with your repair.
Posted on May 27, 2011
Framing air nailgun Senco firing valve part question.
The spring is necessary for the head to reset - check your reassembly to make sure the parts are in the proper order and direction - make sure the piston stop in the firing valve is snapped into the head before you reassemble the gun - the head valve shouldn't fall out when you open the head.
Aug 25, 2016 | Senco FramePro 602 Full Round Head...
I have a mcn150 strap shot that you can squeeze the trigger an it will fire with out placing against a joist hanger
Get some engine degreaser in a spray can. Spray it and let the nailer end soak. Wash it off with more degreaser and wipe clean. You may be amazed!
Dec 22, 2014 | Air Tools & Compressors
How to repair of air leaks out in the plug in of hand held air tools when i depressed the trigger
This problem occurs when the orings in the headvalve and/or trigger valve are worn or just needs lubrication. This also happens when the safety foot does not push the trigger valve all the way in. Easy test. Remove nails and air pressure. Remove the trigger exposing the firing pin on the trigger valve. Connect air and with a very quick motion, depress the firing pin all the way in. If the gun fires adjust the safety foot. If the gun does not fire, remove the head and pull out the head valve. Lube orings in head with plenty of white grease. Reinstall head and test. If the gun fires, time for oring kit or just keep applying grease. If the gun still does not fire, most likely problem is trigger valve orings. Good luck
Oct 13, 2014 | Air Tools & Compressors
I have a bostitch MCN 150 strapshot that does not work in cold weather, under 50 degrees. Is there a fix for this?
Most likely worn orings in the trigger valve (# TVA14). Cold weather usually does not affect the gun, however using wrong oil would. Replace the trigger valve and /or try using power steering or brake fluid as lubricant for your gun during cold weather and regular nailer oil during warm weather as these other fluids may have a long term effect on the orings (cause them to swell slightly). You can test the other fluids for long term effect by placing an old oring in a cap full of oil for a week or so. I use two orings of the same size, one for control to compare against the one in the oil. No big deal. Also check for worn parts in the safety foot and /or worn trigger. If you have a single shot trigger (light color plastic) try using the bump fire trigger. Good luck.
Apr 17, 2013 | Stanley Bostitch Mcn150 Strapshot Metal...
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
Head valve seems to stick during firing of the tool All new part in tool I have 5 tools with same problem mcn150
May 23, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
My 2001 Yamaha warrior yfm 350 makes a loud ticking noise coming from the motor, what is wrong with it????
had the same thing on my 350 the adjustment screw for the valves had backed out had to readjust them and replace lock nuts
Nov 03, 2009 | 2002 Yamaha Road Star Warrior
Where is the fuel return check valve on an 98 24 valve cummins
I assube you mean a B. All 24v B's have three possible places up to '03. One the rear of the head, between it and the fire wall. Two, above the lift pump, the large line T's from the head and the pump returning to the tank. Three, at the rear of the injection pump on the mount. Can't miss em. They are 3/4" or 19mm (same size). Good luck
Aug 12, 2009 | 1998 Dodge Ram 2500 2WD
My car is not firing right,
when your engine breaks a timing belt it bends one or more valves in the engine cylinder head, that is the problem, u have bent valves.
Apr 09, 2009 | 2000 Hyundai Accent
Stanley Bostitch Mcn150 Strapshot Metal Connector Nailer Logo
104 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
