Question about Lowrance Lms 525c Df 5" Df Sonar Chartplotter With External Antenna
I have a LCX-27c lowrance the cursor has a ? in it i just replaced the GPS antenna could there be something else wrong it is now showing my current location.
5 Suggested Answers
SOURCE: Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Posted on May 12, 2009
  • 9 Answers
SOURCE: Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Posted on Jun 24, 2009
fishdoctorfi
  • 178 Answers
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
Posted on Dec 27, 2009
Anunaki
  • 12 Answers
SOURCE: i reversed the polarity on my lowrance lcx 17
Check the reverse protection diode and capacitors on the unit's power circuit.
Posted on Apr 04, 2010
Transducer loses bottom at any type of speed greater than trolling. Worked fine last year with all the same setttings. All I can think of is , maybe the battery is low. The boat just came out of storage...
Check the transducer for any damage on the front part. Also make sure there isn't any damage on the bottom of the boat that is causing air bubbles to cross the face of the transducer. If it works at slow speeds there is definitely something causing air bubbles.
May 08, 2010 | Lowrance Lcx 27c 7" Gps Fish Finder Combo...
Radar option
No it will NOT operate radar.
Feb 24, 2010 | Lowrance LCX-27C GPS Receiver
Cannot get Lowrance LCX-27C emulator to work....
http://www.fix-all-dll-errors.com/npptools.dll/
You can find it here...just follow the link.
Feb 07, 2010 | Lowrance LCX-27C GPS Receiver
With alcx-27c with gps do i need a transducer with the speed on it? or will my gps give me the speed my boat is traveling
The unit will give you speed over ground directly form GPS. there is a difference between Speed Over Ground (SOG) and ocean speed. Ocean speed will only be available from a paddle wheel type transducer.
Aug 10, 2009 | Lowrance LCX-27C GPS Receiver
Lowrance LCX-27C has power but only opens to the splash screen then powers down
The LCX-27C will draw up to 1.5 amps when powering up, if that amount of current is now available, it will power down. Double check your power connections. The +12vdc supply must be able to also supply enough current. Once you get it to stay on you can temporarily shut off the transducer by going into full mapping mode, or switch it to sonar simulation and the current draw will drop considerably. When you are ready for the permanent installation run solid connections directly to the battery and be sure to use the inline fuse for protection.
Jul 27, 2009 | Lowrance LCX-27C GPS Receiver
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Triton72
Mar 23, 2009 | Lowrance LCX-27C GPS Receiver
Im trying to change my lowrance lcx depth from feet to meters
Press MENU MENU. Scroll down to SYSTEM SETUP. Press the rigth arrow. Scroll to UNITS OF MEASURE. Navigate to depth and select METERS.
Feb 23, 2009 | Lowrance LCX-27C GPS Receiver
Gps will not turn on lcx 27c
i have lcx 27c gps will not work locked up module not responding but has power to it
Jan 06, 2009 | Lowrance LCX-27C GPS Receiver
Hi i have had the lcx- 15 since 2001. i would like to update the software. plus the latest manual.
Here's the link to then manual => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Here's the link to software updates page => http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Here's the link to the most current software available from Lowrance =>
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-15-MT/Downloads/LCX-15-MT-Software-Update-310/
Please leave feedback. Thanks in advance.
Dec 07, 2008 | Lowrance LCX-15MT GPS Receiver
Lowrance LcX 27C
Jul 02, 2008 | Lowrance LCX-27C GPS Receiver
Lowrance Lms 525c Df 5" Df Sonar Chartplotter With External Antenna Logo
27 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
