Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
I took out the battery and place it back in, now there's a lil black clock showing off an on then disappears. When i flip the phone open app ERROR 523 and Reset shows up on the screen
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 139 Answers
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information before hand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Posted on May 23, 2011
I can's send picture messages because the Messaging button has disappeared from the list the pops up when you hit Share. How do I get it back?
uninstall instagram and see if it recovers the messaging button...also you can download another messaging app that will pop up which is the exact same thing as using the default messaging app. also you should do a virus scan on your phone in case it disappearing is from a virus.... hope this helps.
Aug 04, 2012 | HTC Magic G2 Cell Phone
Net 10 phone just wont work
Does the inside of the phone show ANY signs of having been in water? Might be slight residue, condensation, corrosion? My GUESS - he dropped it in water and took a week to dry it!!!!
Aug 17, 2007 | Motorola Mobility V170
Don't know what motorolo mobile I have it is a flip cover
Usually the model number can be found under the battery. Remove the back panel and pop out the battery. Look for a tag containing model number, serial number, etc. Pop the model number into Google and it will tell you the name of the phone.
Jan 07, 2012 | Motorola Cell Phones
My phone freezes up, I took out the battery and replaced it again. Now every time it turns on its just a white screen that says "app error 205" and the only option is "reset" I hit reset and it does the...
hi,its a flex problem that could be fixed up.i will advice you take it to a mobil;e phone repairer to fix itb up for you by buying a new flex to replace the faulty one.try to be very careful with your phone handling because its a flip.then try to install an anti-virus on your phone if it has been fixed through the following site,sharemobile.com.thanks.
Mar 09, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
How can I get my alarm clock to show on the front screen?
I don't think you can, unfortunately. The blackberry doesn't allow you to move icons that are within other folders, so you can't move the alarm clock app. I know, it's frustrating!
Aug 09, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Display on pearl flip when closed is always black
John-
It is possible the backlight or the LCD itself got damaged. The good news you is you can replace it.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
Jun 03, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
The internal display diplay of my pearl flip is fine but the external display show nothing when the flip is closed, no clock, no incomming calls nothing but the backlight
I used to be able to see who was calling when my phone was closed. I don't know how it changed. However, I did what I think is called a 'hard reboot.' With the phone on I removed the back cover and the battery. I left the battery out for about 30 seconds. Then I replaced the battery and back cover and waited for the phone to restart. When the phone was powered up my setting was back to letting me see who was calling without opening my phone!
Feb 20, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Applications icons disappeared from my phone
i had this happen as well. for certain icons i had to have my provider refresh my phone to fix i called them to resend the service books and some of apps i replaced using the software manager on my pc.
Feb 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
Nokia 5800 won't turn on
"my phone just says NOKIA and its blank white- no matter what you press, no change even though it is fully charged what to do??? pleeeese help "
I had the same problem, I took off the memory card and de sim card, i turned the phone on... and then off... and then I had put back the two cards, and i turned it on again... I worked
Feb 11, 2009 | Nokia 5800 XpressMusic Smartphone
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
429 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
