Question about Rangemaster 110 (Gas) Kitchen Range
Auto light wont fo off
I have tried putting all burners on at same time and no problem. if i want to use the ovens the auto light flashes as though i want to preset timer and ovens go off. i donot set timers or clock as at night i turn cooker off at plug. gas works fine for burners but ovens will not work longer than a minute before the auto light again flashes and it turns ovens off
  • 906 Answers
Good day,
hope this link below will solve your problem.
ovens
Posted on Aug 02, 2010
I cannot get the big oven on my belling db90 to switch on. the clock is flashing 00:00 auto
Set the clock to manual....a hand symbol..... then try again....the oven wont work on auto unless you set time on and time off
Oct 06, 2017 | Belling Ovens
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
I have a hotpoint stove and the burner in the oven won't come on, the heat element lights up but the burner won't light whats wrong with my oven? susan
Even though your igniter is lighting up it probably needs replaced. They become weak and wont pull enough amps to open the gas valve.
Oct 09, 2010 | Hotpoint RGB745 Gas Kitchen Range
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
My oven wont quit beeping!
if it is an E0-F2 error code then i believe it is for a bad control or keypad.. i would replace both.
Feb 13, 2009 | Ovens
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Whirlpool gas range
sounds like you have 2 problems the first the oven wont light is either a ignitor issue or a gas valve problem even though the ign. glows it may not be drawing enough amps to open the valve.it should be 3.5-5.2 amps at full glow.. have checked that? the over cooking sounds like a thermostat issue.not a lighting issue
Feb 22, 2008 | Kitchen Ranges
Rangemaster 110 (Gas) Kitchen Range Logo
307 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
