Question about LG LC1000 Air Conditioner
My lg lp1010 ac unit is shutting down and giveing me a p2 code what does this mean and how do i fix the problem
    Brigadier General:
  • 4,736 Answers
Here is a link to the Owners Manual for your model A/C unit. It has a troubleshooting guide for the Error Codes. You can download and print the manal.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LP1010SNR&matchedModelCode=NOT_MATCHED&searchEngineModelCode=LP1010SNR&targetPage=support-product-profile&initialTab=documents#
If you don't find a solution there, call LG Customer Support (800) 243-0000.
Hope this helps you.
Posted on May 24, 2011
Code p2 shows on the lcd screen after shutting down. what's wrong?
If its an LG Portable air con, P2 means that the water tank is full and needs emptying.
May 26, 2015 | Heating & Cooling
P2 code is on Alen AC portable unit. Have emptied tank, unplugged, reset and still have P2 code on.
I am not completely familiar with these units but I believe they use a float to determine condensate levels. This float may be stuck in the raised position.
Sep 13, 2014 | Alen C360 Portable Air Conditioner
Portable AC model # LG 1010SNR. There is a message(P2) on the screen and it will stay on for more than a few seconds.
Easy easy!
Remove the batteries and put it again now your remote will function properly. Regarding P2, it means defective air senor. replace it.
Aug 17, 2012 | Heating & Cooling
How do I drain the water from my LG portable air conditioner (LP1010SNR)
Lift up the window securing the AC, and CAREFULLY tilt back the unit. The water lays towards the back of the A/C under the fan.
Apr 17, 2012 | LG Heating & Cooling
I have a ductless window LG airconditioner that keeps show P2; I have lost the owners manual so I can't remember what this means.
P2 indicates a circuit protection shut down. Turn the Unit Off & Unplug it for 15 minutes. Then plug the unit back in, and turn it ON. During that time out, the electronics should have reset and the unit will go back to your original settings. If this continues to happen contact LG Customer Support 1 (800) 243-0000.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Heating & Cooling
LG LP0910WNR portable Air Conditioner error code P2 and shut down
P2 is a water tray full error. I had error once, and it had me puzzled because I have a tube from the back, and unit elevated. It was producing water out the back, so it was clearly draining.
Called LG (very prompt service, no wait times at all).
The girl said that error was water tray, I still didn't believe her.
So I pulled unit from location, and tipped at a good angle.
Sure enough, less that a cup of water drained, and now it works fine.
Jul 07, 2011 | Heating & Cooling
I purchased and LG Model# LP1010SNR on 8-3-10 at Home Depot. It was a floor model and did not come with an owners manual. It has a digital display screen. It is intended to run for several hours at a time...
What happens on this unit is it will suddenly stop followed by a series of chimes. You can reset the unit, but it will end with the same set of chimes. My unit display had a P2 code. As mentioned above, I drained the water (small amount actually) in the shower. Note: There is a cap towards tha bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine. If they can make a GI Joe talk ... why can this unit simply say ... "Please Drain". P2 is so intuitive.
Aug 04, 2010 | LG Heating & Cooling
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
LG LC1000 Air Conditioner Logo
547 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
