My air condition started squeaking and squealing awhile back but I was still able to run it and had no problems with it cooling or blowing. Now, however it will only run for about 30 minutes before it shuts off and will not blow any air out thus not cooling either. I am trying to decide if it is fixable or if I will need a new window unit.
    Sergeant:
    Champion:
  • 229 Answers
Replace the window unit it will cost more to fix than replace.
Posted on May 23, 2011
Weird problem, 2005 Kia Spectra5, after air conditioning or defrost is running for about 15-20 mins, seems like the air stops blowing, even though the fan is running, turn the heat settings to fan for...
you may want to check and see if the cycling switch is defective...it engages and disengages the clutch on the compressor ..i would check and see if the clutch stops engaging when the a/c starts blowing warm
Feb 08, 2011 | Air Conditioning and Heat for Kia Spectra5
My Gestetner dsc530 is squeaking when it prints.
A lot of the smaller copiers get random squeaks and squeals from time to time. Eventually some of them will go away, but if you want to try to get rid of it yourself, a can of compressed air is a good place to start.
Try to isolate the area where the squeaking is coming from, and blow some air into that part. Many times the squeak is from dirty bushings or rollers.
If that doesn't help and you can isolate the noise to a specific set of rollers, clean the rollers with either alcohol or D-ink and see if that makes a difference.
Jun 30, 2010 | Gestetner DSC530 All-In-One Laser Printer
Dryer making load squeaking and squealing noise when starting it up..sometime it stops after awhile,but now it does it all the time.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
eue
Jan 22, 2010 | Maytag MDE508DA Dryer
Air conditioning will shut off during operation
these are bad about two things the connector on the back of the control head and the ignition switch...
Sep 27, 2009 | Chevrolet Malibu Cars & Trucks
Hot Air Blast
this is the probleme with luxury cars ...the venting systheme works with vacum and some thime smal electris motor ...if one is broken or a hose craked ...this kind of stuff appens not much to do but to take the under dash apart and look for the problem, it could also just need a little lubrification on all the moving parts !
Jul 21, 2009 | 1995 Mercedes-Benz E-Class
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
Squealing and sometimes doesn't blow cool
A squealing noise is most likely the bearings going bad in the blower motor. This will slow the motor down. If the blower is not operating at the proper speed this will affect the temperature pressure relationship of the refrigerant. This will cause the unit to put out the wrong temperature. Running the unit to long under these conditions can possibly cause further problems ( including a very high electric bill). I recommend that use do not use this unit untill it is repaired or replaced.
Good luck.....
May 03, 2009 | Friedrich M18CF Split System Air...
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
