Question about Dell E173FP 17" LCD Monitor
My screen is always on power save mode - Dell E173FP 17" LCD Monitor
Verify the monitor configuration using the control buttons in the monitor. Normally there is one that say menu. Navigate trough it until you find the setting for energy, power etc.
Posted on May 23, 2011
    Sergeant:
  • 167 Answers
No signal coming from the cpu just fix the vga cable at the back or if you have a vido card put it in their not on the onboard video output
How do I disable power save mode
Press the Power key > Activate power saving. To deactivate power saving mode, press the Power key > Deactivate power saving.
When activated, the power saving mode turns off some functions automatically. Radio configuration in power saving mode include the cellular radio (it is set to 2G/GSM only mode), the Bluetooth radio (it is turned off) and the Wi-Fi/WLAN radio (scanning for new networks in turned off but existing networks keep functioning). The power saving mode also reduces display power consumption by minimizingscreen brightness and by turning off touch screen feedback and theme effects. In addition the vibra alerts are turned off in a power saving mode. Hope that helps Anomy.
Mar 16, 2015 | Nokia N8
Screen goes into power saving mode
turn off in the settings the power saving mode.
Nov 05, 2012 | LG Televison & Video
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
Why my laptop runs slow when i disconnect the power cable although the battery is fully charged. After reconnecting the power cable the laptop runs normally at good speed, why? is there any problem with...
When you run on the battery the laptop reduces or stops certain things to conserve battery power. Haven't you ever noticed that once you remove the power cord the screen goes dimmer. The laptop is conserving energy and that will cause it to perform at a slower pace or speed.
Unplugged laptops generally go into power saving mode. They will slow the CPU speed, stop the hard drive more often and lower the brightness of the screen (big power savings) all that good effort is lost when you remember that the power supply you use to charge the battery is making more heat . When you reattach it to the power adapter it goes back to Full Power Mode, and recharges the battery as well.
Here's a rule of thumb that I always follow. If i'm near an electrical outlet, I use the power cord. I never use my battery unless there is no electrical outlet near by. This way my battery is always charged for times that I really need to use it.
May 18, 2012 | Compaq Computers & Internet
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Inspiron 1525 pisses me the ********
This is a problem with the BIOS of your laptop. You can do a BIOS upgrade by downloading the updated BIOS from the laptop manufacturer's website. If you close the lid and your laptop goes to sleep mode, your downloads will be halted since you system will go on to power savings-mode (most nics are disabled during this mode). What you can do is let your laptop sit during downloads but change the power savings mode to always on (RC on desktop>properties>screensaver>power>power scheme is always on).
Jun 25, 2009 | Dell Inspiron 1525 Laptop Jet Black
How do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Dell E173FP 17" LCD Monitor Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
